Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I cannot open the draw something is stuck in it
  • 784 Answers
Your dishwasher has a top lid to seal the tube when it in operation. The seal mode is achieved by 2 actuator valves on both side of the housing pulling your top lid down. Model from 603 to current actuators are electric motor. For previous models they are vacuum pump activation.
When the actuators are bad they are either not pulling down the top lid causing a leak, or not releasing top lid back to its original position causing the lid stuck and the tub can not be pulled out as in your case.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see LD or LS, if you pass, keep doing it to get it back in a loop.
4- When at LD or LS, press lock to turn on, press a agin to turn off.
5- Listen to the sound of Actuators and at the same time, try to pull the tube out.
6- When it is done, just press the Power button to get out od the diagnstic mode.
7- If you are lucky, if just the seal to replace then it is easier than repalcing the actuators. Good luck.
Posted on Sep 09, 2009
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
C0920 copier code
First paper draw lift open the draw check behind it ensure no paper stuck back there. REMOVE any STORED EXTRA paper from the draw the extra space is not for paper but if you decide to put 11x17 paper in the draw you need the space.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 07, 2014 | Minolta DI2510 Black and White Copier
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
Sep 23, 2013 | Washing Machines
Key stuck in ignition,engine will not start battery is hot but no lights
If you are saying the battery is hot to the touch, that means something is drawing high current form the battery and you need to disconnect it before you have a fire or the battery melts. Then you need to find the cause for the heavy current draw. The key is stuck because the shift interlock depends on battery voltage to be high enough for it to work.
Jan 26, 2013 | 2004 GMC Envoy
My xbox draw keeps opening and closing
there could be something stuck behind the disk tray, not allowing it to close.
Apr 09, 2011 | Microsoft Xbox 360 Console
I have a 4 draw Plano Tackle box as I have something stuck behind I can't close bottom draw,can you tell me how to remove draw as I've tried and cannot remove regards Sno
Use a long flat blade screw driver with a 1/4 inch blade. From either the right or left side, with the top drawer fully open, take the screw driver and place the blade between the inside of the outer casing and the drawer guide and gently pry the casing away from the drawer guide and pull the drawer open until you release the side catch on the drawer. You only need to free one side, and the drawer will sort of pivot out and the other side will be free at that point as well. Repeat for the rest of the drawers except for the bottom drawer which you will be able to access anything behind it as the upper drawers will not longer be blocking access when removed. I had a small bag of sinkers sitting on the bottom.
Feb 16, 2011 | Plano Four Drawer 757 Guide Series Tackle...
HP Pavillion - DVD & CD drive will not open!
More or less in the centre of the draw front of both drives you should see a small hole.
Get hold of a paper clip and straighten it out, or use something similar, and press it into said hole. It should release the drive draw.
May 02, 2010 | Computers & Internet
I have a Ruud Electic furnance, Model # UBEA-21-J10NFJAI, it has two heating coils and one has burned open. What would cause that element to burn open?
Hi!
It could be a loose connection causing a voltage drop(higher amp draw) on either end of the element or the element shorted out(touching something to ground) or the sequencer contact that gives power to that element stuck closed and the element kept heating without the fan running or just the age of the element (burned out normally). I hope that helped!
Jan 03, 2010 | Heating & Cooling
Dvd stuck in recorder
Power of and some players got small hole next to draw for hairpin to open manual some disk is from diffrent regions code 1 or 2
Mar 20, 2009 | NexxTech EDP3110
My dvd draw does not open on my dimention 4100
maybe something was left inide and stuck...
try inserting a small pin to press inside the small hole there is in the front that opens the try in this cases.
Mar 15, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
237 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
