Question about JVC HD-52Z575 52" HDTV
My Crown CTT3207W 32 in. LCD TV stays on for about 10 secs then shuts off
  • JVC Master
  • 5,568 Answers
If there is no audio or video, it is probably a failing main power supply.
Try the instructions pasted below:
If it's failing to turn on or stay on reliably, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Sep 08, 2009
  • clint May 28, 2011
    Go here for the repair kit which is easy to do.If you can solder then youre okay and the powerboard is easy to remove and does not need genius just a+b+c or 1,2,3. If you know them that all it takes.
    http://www.chsinteractive.co.uk/electric...
  • Steve Allison
    Steve Allison May 28, 2011
    An excellent tip but it should be made clear that a decent soldering iron is required and some practice on the guts of your old 8-track player is advised.
Crown ctt3207w LCD TV won't recognize the PC source anymore
I would check the cables inside the unit. One of them could have come loose during the move.
May 20, 2016 | Televison & Video
Emerson schematics tv clc320
Main board fault. Shorted component/s at it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 16, 2014 | Emerson LC320EM8 32 in. LCD TV
How can i put a crown ctt1506lc in game mode without remote?
I could not find an owner's manual online, so you get a generic answer. Look for an "Input" button among the TV's controls. If you don't find one, go to the TV's lowest channel number (in US TV sets, that's Channel 2). Press the Down Channel button once more. That may take you to the external video input, which I assume is what you want for "game mode."
Jul 26, 2014 | Crown Televison & Video
Why wont my coby stay on?
May 23, 2014 | Coby TF-TV3217 32 in. LCD TV
Keeps shuting off
Some boards or components inside the TV might have gone bad. Might require attention by a qualified service technician.
Aug 12, 2012 | Sharp LC46SB54U 46 in. LCD TV
My power light keeps blinking and i cant get the picture to stay up
mines doing the same thing .. i held down the power button for like 10 sec. until it would stay on .. but i dont think i permanently fixed it .. im trying to figure out what the problem is
Jan 16, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Our picture will only show reds and greens, no other colors.
Go to your On Screen Menu to picture settings and reset and choose "reset picture" mode. This will bring you back to factory defaults. If this doesn't work shut off wait 10 sec. and turn on the TV. If still no luck call your best friend who is a TV repairman, you probably have a damaged blue drive.
Oct 02, 2011 | LG 32LG30 32 in. LCD HDTV
My tv stays on for 10 seconds then shuts off.
sounds like lamp errors.... due to either bad lamps in the LCD, or defective LCD inverter.
Dec 18, 2008 | Sylvania LC320SS8 32 in. LCD Television
My Go Video 32" flat screen HDTV will stay on for 5 to 10 seconds then shuts off!
I have the same exact problem with my Go Video 32" HDTV. Yesterday the power stayed on for several hours, now it wont stay on for more than 5 - 8 minutes.
Please someone help!
TJ@streetkidssoftball.com
Sep 28, 2008 | Televison & Video
JVC HD-52Z575 52" HDTV Logo
503 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
