Question about Belkin F5D8236-4 Router
How do I install my Belkin wirless router with my existing modem and vonage phone adapter
    Scholar:
  • 77 Answers
I am not sure of the specific information you are asking, but my Vonage adapter is plugged into my modem and the router is plugged into the Vonage adapter.
This way the Vonage adapter can throttle the bandwidth used by other devices while in a call state.
Hope this helps, if not please ask more..
Posted on Sep 08, 2009
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 20, 2011 | Belkin Computers & Internet
How can router, cable modem & Vonage modem be connected
Connect the Cable Modem - > The Vonage
Then Connect the Vonage -> The Yellow or Green Slot of the router
Connect your computer -> The Grey slot in the router
Run the Setup
Dec 11, 2010 | Belkin (F5D7231-4) Wireless Router
Can you help me set up my home computer my time warner modem n vonage modem with my belkin router?
So you are trying to set up the router.
you can connect the router to the modem and the computer to the router.
Set up your router properly sothat your computer can go online through the router.
Pnce your computer is online through the router, then connect the Vonage to the router and it should work.
First make sure that your computer will be able to go online when connected directly to the Time Warner cable modem.
Click Here for step by step solution on how to set up router.
Nov 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I can not extract e mails from in box of yahoo mail
Hii
You jus t need to open port numbe 25 on your belkin router with the help from belkin support
Mar 26, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Belkin wireless 'N' with Vonage router and cable ISP modem...
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Nov 07, 2017 | Belkin (F5D8231-4) Wireless Router...
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Belkin F5D8236-4 Router Logo
174 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
