Question about HP Pavilion dv9000z Notebook
Hp dv9700 doesn not start. when i press power button laptop is trying to start but it is not starting. it seems everything is working i just get blank screen with a little of light. and then it shuts down and restarting again.. Anyone can help ?
  • 615 Answers
Try safemode if not check F2 for mem.
Posted on Sep 08, 2009
HP Pavillion dv9700 does not power on
It would seem that the power button is faulty, usually, this is because one or more of the four solder connections by which the switch is attached to the printed circuit has become detached, sometimes caused by pressing it too hard. Rectifying this is quite an intricate job requiring a lot of disassembly and skilled soldering. If you are in any doubt take it to a professional.
Apr 07, 2017 | Computers & Internet
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
I had graphics problem,after resolved by an exprt the power problem starts within a day. Now it is not starting. Do i have to change motherboard?
not yet,,
remove the graphics card, remove the pc memory remove the battery from the board, press and hold the power button for 12 seconds release put back, battery and memory and graphics card turn on, load default values and contine, should be fine.
Apr 04, 2011 | HEWLETT-PACKARD Hewlett Packard 459566-001...
My print screen button doesn't work on my dv9000 and i have tried EVERYTHING
On my HP Pavilion DV9500 with Win7 64 bit (laptop was new in 2007 and had Vista), I have the same problem, and I press FN-insert/scroll key and this works as the print screen button. That's the function key together with the insert key, which is 2 buttons to the left of the print screen key.
numberpad on hp dv9000 Page 2 Hardware Canucks
Aug 08, 2010 | Compaq Laptop Keyboard for HP Pavilion...
I have hp dv9700, after improper shutdown kept rebooting
What happened is that you interrupted the disk write on 'saving settings'. Very BAD. You may be able to start in safe mode, by pressing F8 while windows is starting, then selecting options to attempt to repair. The alternative, is to boot from the windows CD and select 'repair'.
Feb 09, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
I only get all blue light on, but no video when I turn on HP Pavilion dv9700 computer. I tried to remove battery and memory, hold the power for 60 seconds and put everything back, still no luck. When I...
Does the computer seem to be starting all the way to windows? You can test this by playing a CD after it has fully started. If the CD won't play then it is probably not passing the POST (power on self test). If the CD palys it may just be your LCD inverter is bad. In that case you should be able to see the logo but very faintly, right at start up.
Let me know what happens.
Nov 18, 2009 | HP Pavilion dv9000z Notebook
Laptop is not working
the only possable problem is the power source. so most likely your power converter box on the power cord has over heated, which is common, its expensive to replace though($70-85). if the problem continues take it to a shop don't try to repair the internal power converter yourself.
Nov 16, 2009 | Compaq Laptop Keyboard for HP Pavilion...
Keyboad doesnt work hp pavilion dv9823ea laptop
Hi:
The keyboards on laptops are somewhat fragile, and would be the first thing that should be tried. They are not too hard to change, and relatively inexpensive, about $15 on ebay. You could plug in a external, USB keyboard to use temporarily too.
Oct 25, 2009 | Compaq Laptop Keyboard for HP Pavilion...
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavilion dv9000z Notebook Logo
429 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
