Question about Canon Pixma MP450 All-In-One InkJet Printer
Paper jam error - won't print
It says paper jam --- says to clear the paper jam & press ok, but there is no paper jam & it will not print or do anything. What do I do?
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
    What this light sequence means that the printer has a paper jam.
    When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
    How to clear Paper Jam
    Press Continue button twice quickly to see the secondary error code.
    To get the secondary error codes
    When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
    When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
    Press and release Continue button twice quickly to display the secondary error code light sequence.
    Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
    We recommend that you clear the entire paper path when a paper jam occurs.
    To clear a paper jam:
    1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
    2 Open the front cover and remove the print cartridge assembly.
    NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
    3 Remove any jams in the area behind the print cartridge assembly.
    4 Lift the flap at the front of the printer and remove any jams beneath the flap.
    5 Open the rear exit and remove any jams.
    6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
    NOTE: The printer reprints the pages that caused the paper jam.
    Jun 30, 2011 | Lexmark E232 Laser Printer
    Error paper output slot. the paper is jammed clear
    Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
    Ash
    Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    Paper Output Slot Error Message
    When the print head temperature falls, the error is
    automatically cleared.
    Note:
    If the print head temperature exceeds the specified limit
    when the scanning unit (printer cover) is opened, the
    carriage does not move to the ink tank replacement
    position.
    Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Paper cartrige cradle is stuck.
    print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
    Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
    "Clear paper jam" error, but there is no jam!
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    prirweto-i-23
    Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Canon Pixma MP450 All-In-One InkJet Printer Logo
    247 people viewed this question
    old marine
    old marine
