Question about GE Washing Machines
WCVH6600HGG ONLY WHEN TOWELS ARE WASHED, THE TOWELS 95% OF THE TIME ARE VERY WET. FILTER IS CLEAN, PUMPS OUT WATER NO PROBLEM. ALL TOWELS ARE SAME SIZE AND THICKNESS, 8 BATH TOWELS. THANKS JIMZ62
aborcass
  • 2651 Answers
SOURCE: Clothes smell musty like wet towels after washed and dried.
check your detergent you are using, it should be a HE detegrent for High Efficency machines, too much regular detergent will suds up and nver be removed from clothing causing such a smell.a quick test to see if your using too much detergent, grab a sock form oyour drawer(clean one) place it in a glass of water and swish it up and dowen a few times, if soapy bubble wateris present then youre over soaping!
Posted on Jan 21, 2009
  • 77 Answers
SOURCE: Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Posted on Feb 11, 2009
samson39
  • 32 Answers
SOURCE: Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Posted on Jul 24, 2009
SOURCE: Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Posted on Aug 15, 2009
  • 104 Answers
SOURCE: Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Posted on Jan 28, 2010
How do I clean the washer pump filter in my GE-WCVH6600HGG?
please go through this http://www.youtube.com/watch?v=x7rJkWE0nN0
Instructions:
  • Examine if there's a problem with the filter. If the machine isn't draining, spinning or agitating, the washer pump filter may be clogged, and you should clean the pump filter. Other giveaways that the filter may need cleaning include the washer performing an incomplete cycle, the timer not advancing or the washer just not running
  • Open the pump access door with a coin. Remove the pump filter by turning it counterclockwise and pulling it out.
  • Clean the filter with your fingernails, removing all loose debris. Wash the filter under running water until it is clean.
  • Replace the filter. Insert it back into its housing, turn it clockwise and close the door.
  • i hope this helps you ,thank you
    Feb 10, 2011 | GE Washing Machines
    Washer won't spin. Washed bath mats (small) and
    Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
    Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
    Aug 14, 2009 | GE WSXH208A Front Load Washer
    I have just purchased an 8KG Siemens front loader
    Time to call the selling dealer for warranty service.
    Aug 01, 2009 | Dryers
    Clothes have "dirty dishrag" smell after washing
    If you open the door of your Neptune, you'll notice a small trough between the door gaskets (inner and outer) There is a drain at the bottom that can get blocked by lint and other funky stuff. Next time you do a load of towels, take a small dirty towel and wipe that area of your machine out real well. Secondly load a slightly smaller load in your machine. Be sure to use a HE compatible soap...less foaming- it does make a difference.. Also the swishy slushy sound is normal and there is liquid in the drum for balancing...it's normal.. I think with a clear door drain, a bit smaller load .you'll find it won't be smelly.. I've got one of these and the only time it gets ordoriforous is when I've jammed it to max capacity. Let me know if all this helps you out. k
    Jun 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
    HOW DO I CLEAN THE FILTER ON A DYSON DC08
    The 2 piece premotor filter can be washed with mild detergent & warm water ensure you leave it for at least 24hrs to dry. DO NOT FIT IF WET OR DAMP,
    The post motor filter can not be washed it must be replaced with new at least every 12 months.
    http://dysonmanuals.llc.nu/index.htm
    Nov 14, 2008 | Dyson DC08 Cylinder Bagless Canister...
    Mildew smell on cloths
    The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
    If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
    Oct 28, 2008 | LG WM-1832C Front Load Washer
    Front load ge washer does not finish cycle
    This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
    Oct 18, 2008 | GE WSXH208A Front Load Washer
    Wont spin
    I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
    I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
    Sep 17, 2008 | GE WSXH208A Front Load Washer
    Clothes wet and soapy after cycle compleded ,mostly when towels are washed.
    Eiterh your machine is not spining properley or you simply need to clear out your drain filter.... or it could be the pump im thinking your filters is slightly blocked..
    fill the machine with water and lower the waste pipe to ground level and if the water trickles out slowly then its a blockage if not then its the pump...
    if its not the pump then its the carbon brushes on the motor....
    follow this procedure.. hope it helps any problems let us know
    Jan 19, 2008 | Bosch WFMC 3200 Front Load Washer
    Washing Machines Logo
    111 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
