Printer jam the printer says it is jammed but there is no paper in it for it to be jammed?
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
  • 13433 Answers
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
Peoples book
  • 9 Answers
SOURCE: Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Posted on Aug 22, 2009
  • 8 Answers
SOURCE: Pixma mx318 paper jam
The first thing I would do is check if there is any small fragments of paper in the printer. If you still cannot see anything, try getting some compressed air and blown the printer out. If that still dose not fix it, you might have a faulty paper sensor. If the printer is in warrenty, I would try and do a warrenty claim.
Posted on Aug 29, 2009
Testimonial: "thanks. very helpful."
sgoswami
  • 114 Answers
SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&lc=en&dlc=en&cc=us&lang=en&product=3795406
Regards Soumajit
Posted on Sep 21, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Paper jam how to repair
In case of paper jam, switch off your printer. Gently try to pull out the jammed paper. Dont force too much if in case the paper is jammed very hard.
There should be a paper jam removing window behind the printer. Locate it. Remove the back paper jam removing compartment and pull out the jammed paper from behind your printer.
I hope this solution is helpful to you
Thanks
Sep 06, 2010 | HP Officejet 5610 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
jasbo
jasbo
