Question about Garden
John Deer Riding Mower L100 gears will not engage. Belts are all there, worked fine last time it was started up two weeks ago. Now when I put it in gear, it will not move. It makes a different engine sound, but no movement
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Check input drive pulley on top of trans to see if splines are worn out.Does the pulley turn?If so see if the shaft turns as well.
Posted on Nov 13, 2009
John deere stx38 wont drive when in gear
check your oil , there is a sensor that well keep it from working if the oil is to low ( a little low is all it takes to ruin your day)
Jun 04, 2014 | John Deere Garden
What is causing my enginge to stall when I try to engage my mower deck?
Check the seat switch it might be disconnected. It will cut the mower off if you leave the seat without disengaging the deck.
May 24, 2014 | John Deere L100 Series
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
L100 John Deere mower will not engage...belt seems very loose but in good condition.
L100 has a tension spring on them it may have broke or came off. If i can help any further you may call me and i will help you. I worked for john deere for several years. (831)578-4034 thanks wade
Apr 08, 2012 | John Deere Garden
My John Deer 1020 turns fine to the left but when turning to the right the power sterring does not work. It seems to me an intermittant problems. Occasionally the sterring is fine but most of the time it...
open hood to get to top steering gear check for lube and check adjuster worm gear known to crack or break a gear tooth than check thru view plate opposite of the steering cylinder which is connected to the rack&pinion make sure timing marks line up may have skipped a tooth or the thrust pad(shims) have shifted
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Blades wont engage on a john deer riding mower
May be a safety switch not letting the PTO engage the clutch? Also check your voltage at the battery...too low a voltage won't let the clutch engage either. Should be between 13.3-14v at full throttle.
Sep 09, 2009 | Garden
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
