Question about Cameras
Lens will not go back in - Cameras
  • billbuilt4 Sep 08, 2009
    casio dig camera was dropped lens looks straight but will not go back in . I has power and is trying to go but won't
    casio EX-Z1080 has been dropped. I dropped it be fore and lens looked crooked. Believe it or not I just straightened out and worked fine for months . dropped it today looks fine , lens is out , no picture in viewfinder and will not take picture or go back in.
    Brigadier General:
  • 5,158 Answers
What is the make and model and when did this first occur and has the camera ever been dropped ?
robert
Posted on Sep 08, 2009
  • Roberta Smith
    Roberta Smith Sep 08, 2009
    first question does the unit actually even power on. second if it does press menu and power at the same time. it should say the version of the software in the camera.
    second if the camera has an added memory card, remove that and turn on the camera. then reinsert the video card and attempt to power it on again.
    are the batteries in the unit fully charged. it does sound like you have shifted the internal parts when it was dropped the second time. if you are comfortable taking it apart you may have to take it apart carefully and realign the parts. i say you may have to do that. does the lens appear shifted again. gently move it back to center.
  • 854 Answers
It may be that the zoom function is still on, and that the lens is still extended? Make sure that you our not zoomed in.If this is not the problem, than it is possible that a small grain of sand or some other material has become lodged in the outer sections of the lens when it was extended, and that it is now jammed and unable to withdraw into the camera once more. You can try to blow any dirt out. However this might force the dirt farther back.
Does not autofocus
Assuming you've made sure the auto-focus is turned on on both the lens and the camera, remove the lens, turn off the camera. Remove the battery. Wait about a minute. Put the lens back on, turn the camera back on . It's a computer basically. Sometimes it crashes. I've had this happen to me a few times.
Mar 13, 2012 | Nikon D90 Digital Camera with 18-105mm...
Tip
Lens Error
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
on Jul 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
LENS ERROR RESTART CAMERA
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Feb 25, 2011 | Canon IXUS80ISS Digital Camera
Zoom lens is stuck out position...won't retract. Power on button produces yellow flashing light on back of camera, then off again automatically after a few seconds. Any hope of getting lens operable...
Lens errors are quite common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended or the camera has been powered on, but the lens had been blocked preventing its extension.
You can try the following:
1. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
2. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
3. [Try at your own risk] Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
Alternatively, take a look here for some more tips! http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2011 | Olympus FE-340 Digital Camera
Errer #45 kodak v610
The problem seems to be with your lens guide it is out of track so please follow the step below,
Try forcing the camera lens but be careful while doing this if something goes wrong your camera our lens can be damage
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
If no luck then contact your Kodak service centre
Thank You
Oct 01, 2010 | Kodak EasyShare V610 Digital Camera
Lens error of casio EX Z300
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Lens stuck
I just wrote a warning about these "telescoping lens" cameras, You need to get the lens back on track. maybe steady pressure, applied to the back of the camera with the lens on a towel on a table to ensure it remains parallel to the camera body.
May 12, 2008 | Nikon Coolpix L11 Digital Camera
Lens error 25 and 15
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
144 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
