Question about Carrier Heating & Cooling
1997 chevy blazer ,no power to the A/C compressor. Fuse is good. Is there a relay some where??
    Problem Solver:
  • 12 Answers
There is a low pressure switch in the circuit which is what cycles the compressor during normal operation. If the system is low on refrigerant, the switch will remain open. It is probably located on the accumulator if you want to check it, but more than likely you need to charge the system. I hope this helps!
Posted on Sep 09, 2009
Where is relay on 95 chevy blazer wiper motor
I had to change my wiper motor on my 97 blazer. The relay should be in the fuse box, that is under the hood.
Feb 02, 2013 | 1997 Chevrolet Blazer
Can I hot wire fuel pump, 1997 chevy s-10 blazer
Get a wiring diagram of the part of the vehicles system your having
problems with and properly diagnose & repair
Jan 08, 2013 | 1997 Chevrolet Blazer
Blower not working on 1997 chevy blazer
Check the blower motor relay, usually located under the hood in a box, also check the fuse in the fuse panel for the blower motor. If both of those are good then you have a bad blower motor.
Mar 17, 2011 | 1997 Chevrolet Blazer
It is a 1997 Chevy Blazer. I looked under the hood their is no fuse box for a starter relay fuse. I am trying to figure out where it is located. The starter works but the car won't start. We replaced the...
IF THE MOTOR WILL START WHEN YOU JUMP START, THE BATTERY IN THE BLAZER MUST BE LOW. USE A D.C. VOLTMETER, THE VOLTAGE AT THE BATTERY WITHOUT JUMPER CABLES, SHOULD NOT DROP BELOW 9 VOLTS WHEN THE STARTER IS TURNING. THERE IS A CRANK FUSE IN THE INTERIOR FUSEBOX. & A STARTER RELAY UNDER THE HOOD. BUT IF THE STARTER IS TURNING, THOSE ITEMS ARE WORKING. THEY ARE ONLY TO MAKE THE STARTER TURN. GOOD LUCK, DRVOLT.
Jan 27, 2011 | 1997 Chevrolet Blazer
1997 chevy s10 blazerdash wont light up when key
the dash sound's like a fuse, check the fuse box under the hood and in the door jamb on the side of the dash, also check your fuel filter and fuel pump, im betting on the pump because i have a 2001 chevy blazer that has had two replaced and it has 233000km on it!
Jun 04, 2010 | 1997 Chevrolet Blazer
Where is the fuel pump relay located in a 1997 chevy blazer 4-dr.
In the glove box behind a plastic panel. There are 3 relays in there. The fuel pump is the one closest to the drivers side.
Mar 31, 2010 | 1997 Chevrolet Blazer
Where is the fuel pump relay fuse on my 1996 chevy blazer s10
underhood relay center has fuel pump fuse
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_c50676e836a18949
Jan 08, 2010 | 1997 Chevrolet Blazer
Where are the air conditioning fuses 97 chevy blazer located
97 only had one fuse panel in the dash on the drivers side. There is/was a junction block for power that had/has fusible links on the driver side fender too.  a) 20a pwr accy
b) 30a pwr wdo
1) 20a stop/haz
2) 20a horn/dm
3) 20a tl/ctsy
4) 20a guages
5) 20a Eng-1
6) 25a htr/ac
7)25a pwr aux
8) 30a rr defog
9) 20a ecm/batt
10) 20a emc/ign
11) 20a radio
12) not used
13) 10a rdo/batt
14) 10a illum
15) 10a drl
16) 15a turn/back up
17) 25a wiper
18) 20a brake
19) 20a 4wd
20) 10a crank
21) 20a fog
22) 10a air bag
23) 10a trans
24) 10a prndl
The A/C relay is in the glove box behind a panel that indicate relay. There are three relays in there, the middle relay is the fuel pump and one of the out side relay is for the A/C compressor and the other is for the third brake light. Just can not remember which out side relay is the A/C so just swap the out side relays with one another. Good luck and hope this helps. Keep me posted.
Jun 25, 2009 | 1997 Chevrolet Blazer
Heating & Cooling Logo
123 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
