Question about Sony KP-53HS20 TV
Sound but no picture is it the picture tube or just another problem
  • 3 Answers
Most likely will not be the tubes mate, if the tubes go then you just get a big mix of red green and blue colours in the screen - sound but no picture is more likely to be the starter unit on the flat screen.
flat screens have a starter unit - mine went on a samsung but under warrenty
Posted on Sep 08, 2009
Sound ok but no picture
Check the high voltage on the picture tube it should be around 26 thousand volts. Check the back of the picture tube to see if its lit.
Rich
Feb 04, 2015 | Televison & Video
Toshiba model CF30D50 has sound and will change channels, but picture is dark, can see vedio 1 and 2 faintly, but can get no picture on TV channels
Its a older set with 3 picture tubes---when was the last time the mirror and three lens for the tubes were cleaned?
Dec 13, 2012 | Toshiba Televison & Video
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
Has no picture but has sound
I understood your problem there is fault in to your picture tube or it may in supply given to GRID of picture tube because only sound section is working so only sound comes out but not the picture, or also checkout the DEFLECTION IC(both horizontal & vertical deflection IC)
Thank you to give me the chance to help you.
give your ratings please!
Feb 20, 2011 | Televison & Video
No picture the picture worked 4 hrs ago great sound now we ahve sound but no picture
try to check the supply of the heater from the picture tube..check for open resistors..the heater is located at the CRT board it is the board that connected to the picture tube the supply of the heater comes from the plyback...
May 31, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture displayed when switched on
picture tube problem.......change it!!!!
Sep 27, 2009 | Televison & Video
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Aug 12, 2009 | Panasonic Televison & Video
PICTURE TUBE
32 inch Albatran Monivision Moniter, when plugging the VGA in the tower thers no picture. the moniter comes on saying " No Signal No AV Box Action
Dec 16, 2007 | Albatron Monivision 29" Picture Tube...
Sony trinitron no picture but sound
Absolutely! "S and V" line Sonys are well known for bad picture tubes! Replaceset......T.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound no picture
OK CHECK THE HIGH VOLTAGE REGION, FLYBACK AND TRIPLICATOR UNITS. CHECK OPEN RESISTOR IN CRT FOR ALL TUBES AND ISOLATION HIGH VOLTAGE CABLES IN EACH TUBES.
Dec 27, 2006 | Sony KP-53S25 53" Rear Projection...
Sony KP-53HS20 TV Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
