Item trapped under the agitator
How do I remove the agitator to clear the trapped item?
  • bert_lancast Sep 09, 2009
    Hi
    Its a Hoover Elite 1205. However, I have since found that the agitator on this machine can be removed after undoing a screw/bolt located inside the top of the agitator.
    Thanks.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    What is the BRAND NAME and MODEL NUMBER?
  • 631 Answers
Some of the washing machines you can buy a small inner tube and put it around the agitator and slide it under the agitator then blow up the inner tube and the agitator will come off.
Posted on Sep 09, 2009
Kenmore Elite 110.22992 Won't agitate properly. Can't find way to get agitator housing out of machine.
In the exploded view on SearsPartsDirect it shows to remove the cover and there is a "agitator bolt" under it. Item # 22 in the picture below is the cover and the bolt is item # 2. The dogs that are usually bad are # 5.
Feb 06, 2016 | Washing Machines
Item feel into lint trap, how do i remove?
Get one of those attachments that goes on the end of your vacuum. They are made to clean out the lint trap channel.
May 14, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
Kenmore Elite Top Loading Washer: sheet trapped under round base plate at bottom of agitator. How can it be released?
The link below provides the detailed instructions in removing the agitator to remove the item underneath. Click on the link.
Agitator Removal
Sep 05, 2011 | Washing Machines
I have a Kenmore Elite top load washer, model # 110.16972500. I got a shoelace cought under the agitator.
Hi and welcome to FixYa, I am Kelly
Take a look at this link so you can see what parts secure your agitator in place:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0507016-00003.png
Also see this link for item number descriptions:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-11016972500/0583/0153200/K0507016/00003?blt=06&prst=0&shdMod=11016972500
You have to lift off the cap (Item 1) and then the inner cap & washer (Items 22 and 23) to get to the mounting bolt item 21. You will have to use a socket and an extension to remove the agitator mouting bolt. After removing the mounting bolt you should be able to lift the agitator to free the shoe lace. Re-assemble in reverse order. Mounting bolt... inner cap and washer... then the top cap.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
HOW DO I SEPERATE THE TOP PART OF AGITATOR FROM THE BOTTOM PART
Remove top cap and inside of agitator you will find 7/16 bolt i believe..maybe 3/8 either way,..remove bolt and pull agitator up and out of washer..I put the agitator on floor and hold bottom with my feet and pull up on top portion...i do this to replace the agitator dogs
Jan 22, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Where is the lint trap loacated on my machine? Frigidaire ATF7000FS1 model
Hi and welcome to FixYa, I am Kelly.
Download this manual and go to page 6 item 40:
http://guides.homeeverything.com/cache/FRBVHTCGJYGT.PDF
This is the pump filter. You must remove the back panel and then the 3 hose clamps Items 42 (1 ea) and 48 (2 ea) seen on page 6 and pull the coin trap item 41 to get to the pump filter item 40.
There is no "lint trap" per se. Just the pump filter.
Kelly
Dec 09, 2010 | Washing Machines
Washer not aggitating right
REPLACE AGITATOR DOGS THESE ARE PLASTIC PIECES THAT CAUSE THE TOP TO AGITATE THERE IS A SCREW UNDER THE CAP OF THE AGITATOR REMOVE IT AND PULL UP THEN YOU WILL FIND THE AGITATOR DOGS PART # 80040
Apr 30, 2009 | Washing Machines
I need a new agitator for my whirlpool auto washing machine the inner parts have worn and wont turn the top of the agitator when washing
try replacing the agitator dogs first part#80040 from whirlpool cheaper than new agitator approx $6 versus 40-50..remove agitator cap or may be dispenser first under cap will be 7/16 bolt or a 3/8 square drive socket..take it out remove top part may need to give it a good tug to pull loose from bottom section dogs are in cam assembly
Sep 27, 2008 | Whirlpool Washing Machines
WHIRLPOOL MODEL LXR9445JQ0 WASHER. UPPER AGITATOR NOT WORKING VERY WELL, EXCEPT ON SMALL LOADS. LOWER AGITATOR WORKING ALL THE TIME. UPPER AGITATOR CAM BAD? HOW HARD TO REPLACE?
You need to replace the agitator dogs. Yes...there is such a thing. These are four small plastic pieces under the agitator cap that grip the upper agitator, preventing it from back spinning under a load. Searspartdirect.com has an excellent illustration of how your agitator is assembled. Just type in your model number and look under the "Agitator, Basket and Tub" heading. The dogs are listed as item 10 (part #80040). For a bit more you can order the entire upper cam replacment kit (which includes the dogs) as item 9 (285811). For instructions on how to replace, just follow this link:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is an expensive and very simple repair. If you require addtional assistance, let me know. I hope this helps you.
Aug 27, 2008 | Whirlpool Washing Machines
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
