Question about Kenmore Washing Machines
Kenmore 600 series Washing Machine. I can't turn the Washing level switch. It is stuck at low level
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I want to remove the agitator on 600 series Kenmore washing machine
u will have to remove the 7/16 nut bolt inside the agitator about 6 inches down in the center, then remove the top have of agitator with cam dogs, then pull up the other half which may take some muscle as it can get tightly stuck in there thank goodness u wont need the spammer wrench for this job?
Feb 19, 2015 | Kenmore Washing Machines
My kenmore water level switch broke off. i have an 600 series washer. can this be fixed on my own? the washer still functions fine but it is stuck on small load. how to fix it?
yes it is easy to repair there are two screws on the rear corners of the control panel if you remove those the control flips up and you can change the switch. you can order it from sears parts online with your model number
Jun 06, 2011 | Washing Machines
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Does the Kenmore 600 washing machine have an out of balance switch that will turn off the spin cycle when out of balance?
Yes it will turn off if it really starts rocking. If this is happening a lot check the level of the machine and adjust the legs accordingly.
Jan 05, 2010 | Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
241 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
