I'm looking for a how to guide to replace the belt on my dryer it is a samasung dv4006
  • frankhpe72 Sep 09, 2009
    thank you appreciate your time was extremely helpful back in buisness cheers
  • 17,970 Answers
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
Theoriginal belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JWdryers is a Megadyne 1975 H7. The part number is DC66-00121A, but whenordered, a Dongil 7PH1975 belt may be shipped instead of the originalMegadyne. The Maytag MDE2400AZW dryer uses the same belt. The partnumber is 35001010, but when ordered, a Dongil 7PH1975 belt may beshipped. It seems that the Dongil belts are inadequate for thesedryers. They delaminate and may fail prematurely. Even new, they causea thumping sound each time the seam goes over the motor pulley. Otherthan Megadyne, another good belt is the Hutchinson 1975H7. Theappliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBaymember 'appliance-parts' in Colorado, USA has emailed me that theirSamsung DC66-00121A belts are Megadyne. Website:http://appliancefactory.com Email address:partsonline@appliancefactory.com
eBay member 'ladydi1975' inOhio, USA has emailed me that their Maytag 35001010 belts are Megadyne.eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessiveheat in the dryer due to lint in the vent line or vent line too long.The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metalburrs on the steel motor pulley. Deburr by inserting a smallscrewdriver in each groove while the motor is turning without the belt.
--Belton the wrong track. The motor pulley has nine grooves and the belt hasseven ribs. The belt must be in the middle. It's easy to place it onegroove forward or backward by error.
--Small scratches on thedrum where the belt contacts it. The scratches may be like small knivesand damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspectvent line for lint buildup, drum bushing (back of dryer) for wear,motor pulley for burrs and debris, drum for scratches, and idlerpulley/bearing for damage.
--Vacuum all lint.
--Install beltaround drum, idler pulley, and motor pulley. The ribbed side of thebelt contacts the drum. The flat side of the belt contacts the idlerpulley. Press on idler pulley to stretch the spring, and line up theseven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Maybe you can obtain information in the Samsung Owners Manual (PDF Format).
I hope help you with this. Good luck.
Posted on Sep 08, 2009
Samsung dv4006 control panel removal
remove the top with 2 screws on the back then slide back a little then it will lift off. there are 3 or 4 tabs at the top of the console that lift and the plastic will tilt toward the front and lift off to expose the control.
Mar 14, 2014 | Samsung 7.3 Cu. Ft. Electric Dryer
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
How do I remove a Samsung Dryer DV4006 heating element
You will NOT have to remove the drum, as the previous poster said. Unplug the dryer (VERY IMPORTANT). Undo the screws for the cover at the top right at the back of the dryer. Your element is here. Detach it from the cover plate. The undo the bottom cover plate so you can access the plug where the element attaches. You will need to reach in and manipulate the wire out of the clips (easy).
To put it back, just reverse what I've said.
Mar 10, 2010 | Dryers
Belt broke and there is a small plastic part melted lying in bottom of dryer housing that looks like maybe some kind of a guide for the belt+a shoe type device lying in the bottom, looks like the belt goes...
sounds like the plastic take-up pulley on the motor which is spring loaded to keep the drum belt tight. You will have to replace the tensioner which should, depending on the model, include a new plastic pulley.
Oct 16, 2009 | Whirlpool LGR3624JQ Gas Dryer
Samsung dv4006 dryer belt
After four new belts.
There is only one solution , load the dryer into a UPS truck and ship it back to Samsung . Put a note inside and tell them to stick to TV's and stay out of the appliance business .This is the cheapest solution short of filling up the landfill . Believe me this is a lot cheaper than buying belts
Cam
May 15, 2009 | Samsung 7.3 Cu. Ft. Electric Dryer
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Remove top cover.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Clothes Dryer belt assembly
yes,make sure you have the ribbed side on the drum-mike
Nov 04, 2008 | GE DCVH515EF Electric Dryer
Samsung DV4006 dryer heats but does NOT turn
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like you need the belt replaced !
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Dryers
I need a belt for my samsung dv 4006 dryer
Yes!
Global electronic supplies Inc
5600 Timberlea BLVD
Mississauga ON
L4W 4M6
1-800-668-8776
Feb 15, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
