Question about Samsung HT-X20 Home Cinema 600W Theater System
LG dvd receiver
Does not want to play dvd says check regional code
  • 3 more comments
  • Lenny 3006 Feb 22, 2008
    I have an LG DVD receiver. When I try to play Region 1 DVD's the machine displays a warning to check region setting, I cant find a fix for this problem.
  • Anonymous Feb 29, 2008
    HI LOOKING FOR UNLOCK CODE FOR LG THEATRE SYSTEM LH T550
  • Anonymous Mar 14, 2008
    fastinnerhtml!
  • Anonymous Jul 04, 2008
    wrong region
  • Anonymous Oct 22, 2008
    I have a LG DVD Home Theater LHT 854 . When I try to play Region 4 DVD's the machine displays a warning to check region setting, I cant find a fix for this problem. Some DVD run other don't.
  • 5 Answers
Switch on dvd without disc and let it load till it shows no disc. open tray and using a remote control enter four zeros. region edit will appear and press zero and press enter and then pulse on remote.switch off dvd and on again.dvd is region free. notify me if this works email alfredmalambo@yahoo.com
Posted on Feb 05, 2009
Alfredsaviou his solution works i have fixed several DVD players thank alfred
Posted on Apr 19, 2009
Hi. It worked. Thanks a lot. I don't know how you figured this out but it worked!
Posted on Feb 07, 2009
2 Suggested Answers
SOURCE: lg dv340 how to unlock regional codes for all codes
st1\:*{behavior:url(#default#ieooui) } Region Free Hack for LG DV340 DVD Player As I’m currently in South Africa visiting my family, I bought a DVD player as a prezzie for mom.
LG DV340 Region free hack for the model I bought at Game is below:
1, power on the player with no disk in the drive
2, pres pause on the remote
3, enter “314159′ on the remote
4, enter “0′ on the remote (0 = all regions, 1 = region 1 etc)
5, press pause on the remote
6, power the player off and then back.
Hopefully this helps someone else!
(Info from http://forums.dvd-swaps.co.uk/archive/index.php?t-2327.html)
Tags: dvd, lg dv340, region free hack
Posted on Jan 13, 2009
Need region code to unlock LG dvd home theatre HB905PA
If you live in the US your region code is 1
if you are able, put in 0. this will allow you play DVD's from all over the world regardless of region code on the particular DVD.
DVD region code
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Sep 15, 2010 | Audio Players & Recorders
What does check regional code mean?
It means your DVD player has a different region code to the disc you are attemting to play.
DVD's and most DVD players have a region code corresponding to the country/region in which they were purchased. The region code printed on the disc must match the region code of the player, usualy found on the rear of the unit or in the manual. Only players set to code 0 or 9 are able to play all regions, a setting of 1- 6 is most common. 1 = USA 2 = Europe etc.
It is often possible to set your player to code 0 or 9 enabeling you view all region DVD's.
May 16, 2010 | LGDVB418 DVD Player
Region code error for my LG RC388 DVD/VCR player & recorder
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Please rate our Free help to keep the service online ++++
Aug 30, 2009 | Televison & Video
Is there a way to make my LG DVD multi regional?
please check this thread from answersbag.com
"1. Insert the DVD with Region Code which will not play. 2. Press 0000 on the remote and a new screen should appear showing Region Code for the LG V271 (as Region 4). 3. Select new region code as 0. 4. Press Pause to exit the screen and your LG V271 should now be region free."
Aug 02, 2009 | LG V271 DVD Player/VCR
How can LG DVD Writer on my HCL PC be made Region Free. I am unable to play region 5 coded DVD's on PC. No options are left to change the code. BTW, why DVD players are coded with region codes??
there is a program called region free http://www.dvdidle.com/dvd-region-free.htm you can pay for it or just find a crack version via a torrent online. that will enable you to play any region dvds
Jun 28, 2009 | LG GMA-4020B Super-Multi...
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
Region problem with LG DVD RH265
no problem! I just bought a LG RH265 and made it multi region with no problems:
on your remote-
1) press HOME
2) move to SET UP
3) scroll down to LOCK (no need to enter LOCK options)
4) press "0" seven times
5) a message will appear stating the dvd player is region free.
6) ENJOY!!!
Dec 10, 2008 | LG LST-3510A DVD Player/Receiver
Need to play region 1 DVD in region 2
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Samsung HT-X20 Home Cinema 600W Theater System Logo
370 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
