Question about Lexmark X73 All-In-One InkJet Printer
I'm using a Lexmark X73 printer (donated from my son) so that I can print B/W and some colour. Plus use the scan feature. My system is a Mac with the latest softwear. I did purchase new ink cartridges by taking the old ones to Office Depote and (I believe correctly installed them). Also, I'm send the "print command" through apple extreme. The problem shows up as "in cartridge not conneted". What do I do? The mac system recognizes the printer. Please help. Please reply to vbca@rogers.com. Thanks
Unable read cups raster data os lexmark
It's a Driver issue. You need to reset the printing system by deleting the current printer and re-adding it, like this:
  1. Click the Apple menu, and then click System Preferences .
  2. Select Print & Scan.
  3. Right-click (or Ctrl + click) your product in the Printers list in the left panel, and then click Reset printing system .
  4. Click OK to confirm the reset.
  5. Type your user Name and Password .
  6. Click OK . The printing system resets.
  7. Next go to the Library\Printers folder and move the Lexmark folder to the trash.
  8. Under Print & Scan, click the plus sign and re-add the printer.
  9. The drivers should be reinstalled automatically.
Oct 31, 2013 | Computers & Internet
Lexmark x73 printer offline?
is the printer driver compatible with your computer. see if your printer runs with the windows you are useing.
Nov 12, 2011 | Lexmark X73 All-In-One InkJet Printer
I have HP Pavilion laptop and trying to install Lexmark x73. I cant get it to work. Is it possible to install.
Please visit the Lexmark website to download and install the Lexmark X75 printer driver on your computer. Note that the drivers available are only for Windows XP 32-bit, Windows 2000, Mac 10.3 and previous versions of Mac.
Sep 03, 2011 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 not pulling paper through properly, overprinting lines, part printing documents and printing some lines in colour shadowing the black print. I have used different grades of paper but still the...
Your printer's rollers sound like they are worn along the paper path. I suggest you taking your printer in to have a maintenance cleaning or have the rollers replaced. This will resolve your issues.
May 28, 2010 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 Printing Problem
When you say that your all-in-one system will copy, but will not print from the computer, this tells me that there could be a connection problem between the printer and the computer. This is more then likely a driver problem. you will need to go to lexmark and download the latest drivers for your operating system.
But this could also be a broken or loose cable.
Apr 15, 2010 | Lexmark X73 All-In-One InkJet Printer
Printer works, copier and scanner do not
you might try enabling bi-directional printer support in printer properties, if its paralell cable then it is in bios, epp or ecp.
Jul 27, 2009 | Lexmark X73 All-In-One InkJet Printer
I have a lexmark x73 i'been instaling so manytimes on order to make the scaner to work but nothing I would apreciatte if you can give me some tips or help thanks
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X73) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X73 All-In-One InkJet Printer
Lexmark x73 printer
Install or reinstall driver from Lexmark... here is the link below http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X73
Sep 16, 2007 | Lexmark X73 All-In-One InkJet Printer
Lost the CD
If you go to the US website, then it will scan your system for a printer then install driver http://www.lexmark.com/lexmark/site/home/0,6932,204816596,00.html Otherwise you can download the driver here http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=227:5:0:94:0:0&emeaframe=&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::::
Mar 03, 2007 | Lexmark X73 All-In-One InkJet Printer
Cannot print unless I turn off computer and then reboot.
I'm not a big fan of Lexmark in general in part due to their software and drivers. For me this type of behavior from their printers/software became common about a year ago, the fix being to use the more generic Windows supplied printer drivers. I would suggest that you uninstall all software the printer installed and remove all of the printers print queue(s)including any associated with the fax function. Unplug the printer USB cable from the computer, reboot your PC and reinstall the printer from scratch using your original installatin CD.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
