Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
How long do i need to charge my battery for my swivel sweeper?
  • 34 Answers
24 hours .
Posted on Sep 12, 2009
Swivel sweeper brushes slow with full charge even after cleaning brushes
When you say you cleaned out brush's are you talking about the build up between the bristles? I've found that I have to take the roller completely off and use fine needle nose tweezers to actually get all the stray hairs and caked on dirt as it hides close to the inside of the brush rollers. It's a bit more work to do this but I think you might benefit from this extra step!
Good Luck!!!
Jan 23, 2013 | As Seen On TV Swivel Sweeper Vacuum
New swivel sweeper dont work
the answer is......
they're a pos and are a waste of your money
Jul 16, 2017 | As Seen On TV Swivel Sweeper G2 Cordless...
What would cause this to shut off after a few minutes of use with full battery charge
1) test the power cord for open, broken, loose or defective with VOM
2) test the outlet wall, for ground improperly, and repair.
3) Most of the time is THERMAL fuse, replace or fix it.
God bless you
Jul 27, 2012 | As Seen On TV Swivel Sweeper Vacuum
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
I bought a new battery charged it, and it starts then slows to a stop?
Possible that the drain of the mottor is exceeding the current requirement of the battery.
So check the battery for voltage and current according to the standard set, then check the vacuum motor to work from another source to determine the currrent factor to confirm if there is a mismatch or poor efficiency.
Sep 16, 2010 | As Seen On TV Swivel Sweeper Vacuum
Brushes don't turn, light works when switched on, battery fully charged
Hello. Generally, when the brushes don't turn you will find that the belt is broken. In some cases, also the brushes will stop if they are clogged up with animal hair, etc. Regards, Joe
Dec 14, 2009 | As Seen On TV Swivel Sweeper Vacuum
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Battery or ?
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 10, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Swivel sweeper battery is not charging
The battery is done for sure. take a look here Finally charging for our multi device world and choose the best one for you (by price and seller). cheers
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
129 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
