Compaq turns on, all lights lit, screen comes on and then off quick, with a pop, then can not turn the computer off with the button
    Brigadier General:
  • 4,044 Answers
Sounds like something got spilled on the computer and has shorted out motherboard or Screen controller. Take the computer to a service point and have it checked out.
Posted on Sep 08, 2009
The screen wont light up on my compaq nc6230. you can just barely see the icons because the screen is not lit up. can i turn the back screen light on or is it damaged and need to be replaced
There is a screen brightness function on your keyboard, press the Fn key and the appropriate number key with a picture of a screen or sun on it. There will be two, one brighter the other darker.
If that doesn't work, you've probably got an inverter fault, or the ribbon connector has come adrift.
Different with most laptops but, remove power and batteries, check between the keyboard and the screen, there could be a plate which is clipped/screwed into place. Remove any screws and, very carefully, prise the plate off.
Look for ribbon connectors and make sure they are home and sound.
If one was loose, you've possible resolved the problem, if not, then you'll have to get it replaced.
Sep 12, 2010 | HP Compaq nc6230 Notebook
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Compaq parcerio 2000 laptop web connection light will not come on
did you refer to the wifi light? actually wifi radio receiver is a manual thing and you should turn it ON and OFF manually. Im not sure with the model you described but try to look for a slide or push button with the wifi icon (an antenna with 3 waves). then try to see if the wifi led is lit. Another way, if your device is soft touch, then there is no hard press button for it. it will be a combination of FN + a function key (look at the function key with the wifi icon)
Sep 01, 2009 | Compaq Presario M2000 Notebook
My Compaq keyboard has a key with an icon shaped like a moon. What is that for? Also, ovedr the number pad, there is a light on the right that has an arrow pointing down. What is that light for. Also, my...
The Moon key is for putting your computer to sleep, the keypad light is probably the NUM LOCK LIGHT. When your screen blacks out will it come on again if you press enter on click the mouse button? if so, go into the control panel, click on the power options and look for the icon marked 'Screen' or something similiar. Change the timing to an hour or so...
Jun 03, 2009 | Computers & Internet
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
When you attempt to power on the compaq n600c it turns on and off repeated. the power lights come on and off, but the screen never pops up.
Try Taking The Memory Out And Then Turn it On, Then Turn It Off, And Put It Back In. Or Try Another Slot. Hope That Helps.
Jan 15, 2009 | HP Compaq Evo Notebook N600c
Compaq presario c500
i have the same problem i used another fully charged battery and the computer comes on says on the taskbar that its charging ,but its not when the battery completely drains it them wont come on at all only the power button flashes quickly
Sep 07, 2008 | Computers & Internet
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
