Question about Acer Extensa 5630-4933 Notebook
What is the maximum hard drive capacity that acer 5630 bl50 will support
    President:
  • 2,600 Answers
As much as yiu can stuff in it. I think the largest at this point is 500GB. I have included a link below for the service manual and specs for that model. Copy and paste the link to your browsers address bar, hit enter. Make sure to make a copy for yourself for future refernce in needed.
http://tim.id.au/laptops/acer/aspire%205680%205630%203690%20travelmate%204280%204230%202490.pdf
Posted on Sep 08, 2009
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
My laptop ACER ASPIRE 5630-BL50 was formatted. so i need all the drivers for my pc to work effectively. i've searched online but couldn\t get the desried drivers. pls help me out.
Hi
Did you go to the acer website if not please click on this link go to support/downloads
type in your make model and operating system as in xp or vista or windows 7 www.acer.co.uk
good luck
Jan 17, 2011 | Acer Aspire 5630 Notebook
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Jan 24, 2010 | Acer Aspire 5630 Notebook
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Maximum HDD capacity of an ACER Travelmate 212 TX
Yes you can install a 20 Gb hard drive but I doubt you can buy a new one with that small capacity. The smallest capacity hard drives are approx. 80 to 100 Gb or greater.
You most likely can buy a 2nd hand drive but you don't know its quality, it may have had a hard working life and you don't know how long it will last, but then, if is very cheap that may not be a problem.
Mar 31, 2009 | Acer Computers & Internet
I want mother board drivers
just click this link then you will be redirected:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Sep 19, 2008 | Acer Aspire 5630 Notebook
Acer aspire 5630 BL50
You can try basic troubleshooting. Unplug the laptop, takeout the battery. With the laptop still unplugged, put the battery back in and power-on the laptop. If that doesn't work and you hear no beeping sounds, the motherboard maybe bad and needs replacing.
Apr 05, 2008 | Acer Aspire 5630 Notebook
Model bl50
but whats ur problem??? , pls be specific..
Dec 17, 2007 | Acer Aspire 5630 Notebook
Acer Extensa 5630-4933 Notebook Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
