Question about Southbend SLGS-22SC Gas Double Oven
Pilot light won't stay lit - Southbend SLGS-22SC Gas Double Oven
    Scholar:
  • 77 Answers
Possible a bad thermocouple, could also be bad gas pressure to the unit, my bet would be a thermocouple.
You should be able to replace this on your own, if you see where the pilot flame is, you will see the thermocouple that sticks into the flame, it may have fallen off or may need replacing, it should lead back to the gas valve and should be replaceable.
Grainger normally stock a lot of thermocouples and could even cross reference one for you.
Posted on Sep 08, 2009
Blodgett pizza oven won't stay lot. Pilot stays lit as long as oven is off
Sadly when dealing with GAS I prefer not suggesting any self repairs . call a certified gas repairman .
Sep 25, 2015 | Blodgett Ovens
Royal commercial oven pilot
replace the thermocouple first. it can be purchased at you local hardware store.
if that does not fix it, you will need to replace the Baso, pilot safety. that can be purchased at partstown.com
Jul 07, 2013 | Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
I have a frigidare gas stove I have changed the ingnitor bar and it still wont light, it seems if there is no gas coming in to the oven. Altough the top burners still work
Good day!!!
Your pilot light might have gone out. If this is the case then you have to re-light it. If the pilot light won't stay lit, then you might have to adjust the thermocouple or move the pilot light closer to the burner.
I hope this information will be helpful..
Thanks for using fixya..Have a nice day!!
Aug 27, 2011 | Explorer Appliances Ovens
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Don't know how to light the pilot light in the oven.It is a Garland ten burner two ovens. It is about 11 years old. Where is the pilot light and how do I light it.
Most commercial ovens have a manually lit pilot. There will be a button somewhere on the range that you will need to push in so gas will come out of the pilot assembly. While holding this button you will the light the pilot and will need to hold the button in for about a minute or two until the pilot stays on after you release the button. Look around the bottom panel,top panel or side panels(you may need to remove one) to find the button. they are usually red and may not look like a button. If you find the button and the pilot does not stay lit then the thermocouple might be bad. If you push the button and do not get any gas coming out of the pilot then there might be debris in the pilot assembly causing the gas not to come out. In that case you could try and tap the assembly or blow with compressed air to clear it. But in most cases you will need to remove the pilot assembly and use a really fine wire(like a metal tie-strap minus the coating) to clear the pilot orfice.
Sep 30, 2009 | Garland Ovens
I ran out of propane...so now truck is filling us up..how do I get the oven working again..how to light the pilot light?
Hi there, hope this helps. On the front of the oven, usually on the left side, where your thermostat is, has a red button sticking out, that is your pilot safety. To light it, you need to open the lower door, and aprox. in the center of the area, is your pilot, has a small pipe going to it, you have to hold the red button in, and light the pilot in that lower chamber, and most of the time, once the pilot is lit, you must hold the button for 60 to 90 seconds. If it does not stay lit when you let go of tthe button, you may have additional problems, let us know. And thank you.
Feb 20, 2009 | Bakers Pride Y-600 Gas Single Oven
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Southbend SLGS-22SC Gas Double Oven Logo
592 people viewed this question
Top Southbend Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
Paul Bade
Are you a Southbend Oven Expert? Answer questions, earn points and help others
