Question about McCulloch Garden
I have a Silver Eagle McCulloch Gas Blower. Mod 400048-14 Ser # 16-039739. What fuel mixture does it use? AND It has no spark. Plug looks good but a new one might help. Ken
  • 124 Answers
The fuel ratio is determined by the oil and not the machine. Not all
oil is the same. When a manufacturer recommends a fuel ratio,
they are trying to direct you to the oil that they offer for sale. Over
the years 2 cycle oil has been offered in 16:1, 32:1, 40:1 and 50:1 .
Unfortunately for the user it is easy to get confused when selecting
oil. It is not difficult if you just think about it. There are two major
differences in 2-cycle engines. There are water cooled and there
are air cooled engines and the oils are entirely different. Water
cooled (outboard) engines run at much lower temperatures and at
much lower RPM's. It is necessary for outboard oils to burn during
the combustion cycle. In this situation the oil turns to smoke so
that the oil is not deposited in or on the water. Air cooled engines
run at a much higher temperature and must not be used with
outboard oils. In an air cooled engine the oil should leave the
muffler in liquid form. If the oil turns to smoke it is not able to
lubricate the engine and a very undesirable carbon deposit is left
behind leading to engine failure or stuck piston rings.
Since a top quality mixing oil will cost $12 or more for a six pack
(that comes out to well over $100 a gallon of oil) there is little
wonder that so many companies want a piece of that pie. Cheap
oils no bargain even if it is free. If the oil says it is for outboards,
lawn mowers, string trimmers, and chain saws, they are telling you
that they know nothing about 2 cycle engines and only want to take
your money.
You should choose an oil whose brand is that of an engine
manufacturer. Obviously these companies are not in the oil
business but they want to make sure that they do not cause
warranty claims from an inferior oil. The life of you engine is
dependent on choosing a good grade of oil. You should pick an oil
that you trust and that you can purchase on a consistent basis.
Unlike gasoline, oil does not deteriorate with age. It is better to buy
enough to last you a year or two than it is to change brands every
time you run out.
Posted on Sep 14, 2009
Fuel mixture ratio for an eger bevear blower
Check your fuel cap it might be on there molded in the plastic,if not call your local service center and they will be glad to help! One more question how does one own a blower that mixes fuel and one does not know this answer. Confucius says? Anyways Good Luck PAL
Apr 28, 2010 | McCulloch 26cc Gas Blower Mcb3208
I have an 28 cc McCullogh leaf blower which will
Check for spark in the new spark plug, if you have spark clean the carb fully and try again. make sure you have correct mix of gas to oil and it is not old use fresh gas oil mixture. Good luck pal.
Jan 23, 2010 | McCulloch 26cc Gas Blower Mcb3208
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Ran great sat. but would not start sun. same gas changed plug air filter gas soaked with it off still not running tried putting gas in spark plug hole still not running this is a craftmans 2 cycle leaf...
Were you running a fuel mixture of 40:1(3.2 oz of 2 cycle oil to 1 gal of gas), that you mixed up before you started using it again. The unit may have had to much use on Saturday and may be burned up. Try to have a compression test done on the engine, needs to be at least 100 psi to run. If that proves to be good then you can start looking at Fresh gas mixture, a new spark plug, Carburetor rebuild or an ignition module.
HTH
Good Day.
Oct 26, 2009 | Garden
McCulloch Chain Saw Mod.600133C, need to know the proportion of
oil, gas ratio is 40 to 1 A plug for small gas engines will work
May 08, 2009 | McCulloch Garden
I'm looking for a free downloadable owners manual for a McCulloch gas trimmer, model 1385L, or at least to find out what the spark plug gap should be.
spark plug gap is .025
spark plug recommended for this trimmer is DJ8J
Or RDJ8J if you dont want radio interference or if you do not like champion plugs NGK isMB6F
torqed at 110-120 inlb.
May 05, 2009 | McCulloch 26cc Gas Blower Mcb3208
Trying to get McCulloch MS354 35cc chainsaw started
Stiff usually means good compression. So, pump the fuel bulb, put your foot on the flat in the handle, lock the throttle open using the button on top, set choke all the way out and pull. It should kick after a few pulls. Then close choke half way, and pull until it starts, then push choke all in. If it doesn't start, disconnect spark plug and take it out. Have someone watch while the sparkplug is held against metal engine to see if there is a good spark at the plug. If not maybe needs new coil. look at plug to see if it is wet, ie, gas is getting to it to isolate problem to carburetor.
Apr 27, 2009 | McCulloch Garden
I just foun out that i forgot to add oil to gas mixture to my blo
hello, what you should do is drain out the gas from the tank into a clean container so you can add the oil to it and you should also check your spark plug make sure it's o.k. after draining out the gas try starting the blower a few times with out the spark plug wire connected to the spark plug this will flush out and of the pure gas from the fuel lines, after doing this re-connect the Spark plug wire and add your fuel/oil mixture and re-start, it might take a few times for it to start due to all the gas in the engine but it'll start also if your blower has a primer bulb you may want to prime it a few times after adding the fuel oil mixture to get it in the combustion chamber, if after doing this you still get nothing you'll want to re-place your spark plug it might be fouled out. good luck
Mar 25, 2009 | Craftsman 4 Cycle Blower/Vac
Fuel mixture for 32 CC McCulloch leaf blower
Gas to Oil ratio is 40 to 1. (40:1)
Oct 12, 2008 | Garden
Garden Logo
246 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
