Question about Ice Tech KEO MP3 Player
Computer doesn't regonize or charge my mp3 player
Computer doesn't regonize or charge my mp3 player. on the bottom right hand of the screen, it shows a Udisk with an X above it. When I click that it gives me an option to convert music files but not upload them. Also, the usb is not charging the mp3 player. BTW this is brand new mp3 player.
  • 313 Answers
Make sure the player is OFF before you plug it in and while you transfer you music or charging. Sounds odd but that is it in a nut shell. But here is step by step:
In essence it is as easy as copying files from one folder on your computer into the other.
1. Make sure your player is turned “OFF”.
Important Note: Having player “ON” when plugging and unplugging from computer may delete all files on the player.
2. Connect your player to any USB port on your computer via provided USB cable.
3. Computer will find it as a removable external hard drive.
4. Double click this drive to open it.
5. Open your music/video/text/image files folder in another window.
6. “Drag-and-Drop” your files from your directory on the computer to the root directcomputer doesn't regonize or charge my mp3 player - faq-2-3.jpgplayer.
7. Once the files are copied – disconnect the player from computer.
8. Turn KEO "ON" and go to the desired Mode ("Music", "Movie", etc..) Your newly-copied files should be visible there among other media files preloaded on the player. Use arrow buttons to scroll through them.
IMPORTANT NOTE!
Avoid creating separate folders for every 2-3 songs. Preferably put all audio files in he same “MUSIC” folder, or sort them by "Artist Names" folders or just store all in the root directory (do the same with VIDEO files).
KEO does not support playlists at this time and excessive amount of 2-3 levels of folders may noticeably slow down the operational speed of the unit.
Posted on Sep 08, 2009
I plugged my mp3 player into my computer and how can I tell if it is charging and when it is done charging?
Go to "my computer" (or whatever it's called in your operating system) and right click on the MP3 icon, pick properties it will show a battery with the percent of charging.
Aug 12, 2016 | Eclipse Fit Clip 4GB* MP3 Player
If i plug my player to pc it shows charging and full charge but if i disconnect it will appear lowbat in the screen. and my pc doesn't dettect my unit
Try turning off the player and then back on again. The battery status should update and show full charge. Restart your PC and reconnect the player and it should appear again.
Simply pulling out the USB cable can cause a communication error, so it's always best to use the 'Eject USB device' option. When you want to disconnect, the player will be listed as an external hard drive when you open up 'My Computer', right click on the drive and select 'Eject'.
Jun 13, 2011 | SanDisk Sansa Clip MP3 Player
Does not charge or play,read on computor
In order for the Coby to charge while connected to the computer or other charger, the Coby must be OFF before being connected to the computer. Check the following questions....
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging in the battery area - upper right hand corner.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge with the player OFF.
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Let it run on music until it turns itself off. Recharge as above.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Not sure if player is charging
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
e. You will see a USB connector icon on the player screen and the player charging.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps.
My mp3 is froze and says, please wait........ welcome
i had the same problem so i tried to hack it but theres no way of reseting the software take it back and request a new one this model has alot of issues in the start up menu.....hope this helps
Dec 25, 2009 | Coby MPC-848 MP3 Player
Cant get it to charge
I tried to reset and it didn't work, They way I figured out was to shut it off then plug the USB in. Then the screen shows up where it is sleeping, Then hit the power button one time and in the bottom left the USB light came on and in the top right you can see your battery taking charge. Hope this helps, It took me about three weeks to figure out
Jan 20, 2009 | GPX ML648B MP3 Player
Screen stays black after splash screen
ooh you got big problems .. i think do your computer regonize the mp3 player? can you see the partitions on the mp3 player
what os are you using xp,vista,ubuntu,mac,kubuntu.....
i hopes that this is useful
maby you can reinstall the whole mp3 serch on google and you find much information
Jan 20, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 player
if you plug it into your computer, and your comp says it recognizes it then it will charge. look on the bottom right of the mp3 screen a green bar will move and a lighting bolt will flash if its charging
Dec 21, 2007 | SanDisk Sansa e250 MP3 Player
Delete
when you pull up your music delete it on the computer while the mp3 is plugged in
Oct 21, 2007 | iLO (2 GB) MP3 Player
Ice Tech KEO MP3 Player Logo
157 people viewed this question
Top Ice Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ice Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
