Question about Pioneer DVR-107D DVD±RW Burner
Non-opening dvd/rw hey... can you help me find a way to fix my dvd/rw. when i attach it to the cpu the dvd light just turns on and doesnt stop and then the dvd/rw wont open... can you guys help me?? some people say its broken.. can you help me please... =D
  • arthum_619 Sep 11, 2009
    hey again.. i tried the pi hole and it opened... but only small opening.. i had to pull the tray to open it.. but when i closed the tray and opened my computer, theres still no dvd/rw... what should i do next? can a computer technician fix it? or is it really broken and cant be fixed? please help me... if you have a small trick to fix it so please teach me.. this is very important sir... hehe thank you very much!!
  • 448 Answers
Continuous blinking of indicator on the DVD-RW drive indicates that the drive has frozen or hardware malfunctioning has occurred.
Disconnect the DVD-RW from the Computer and check whether the power cable and the data cable are fully operational. You may also try using different cables.
Install the DVD-RW into the Computer and check if the disc tray is ejected. If not, then use a sharp pointed pin to push hardly straight in the hole located on the front panel of the drive.
If the DVD tray doesn't open and the the indicator keeps on blinking then the issue is related to internal hardware malfunctioning and service will be required.
Posted on Sep 08, 2009
    President:
  • 3,278 Answers
Unfortunately, I'll have to agree with the others - your DVD/RW drive needs to be replaced.
Try attaching the drive to another CPU and I suspect that will confirm it.
  • NinaE Sep 11, 2009
    Unfortunately, the drive will need to be replaced, since there is a mechanical problem. It's tough, I know. It'll cost around $100 for this drive. I've never looked into repairing the drive, but I imagine it would not be cost-effective.
    Just thought I'd ask - is your system still under warranty ? If so, call your manufacturer - I'm not certain if this is covered, tho.
    Problem Solver:
  • 14 Answers
Well, it may have got jammed. so try this trick.....
If you look at the dvd/rw drive..on the side of the button of the drive...you will find a very tiny hole so take a paper pin and insert it in the tiny hole if the drive is opened great!!! otherwise get it replaced as the dvd/rw drives are not costly thesedays..
My dvd player starts then stops and the light keeps blinking.Can someone tell me what's wrong?(AOpen DUW-1608/ARR Chameleon 16x4x16x DVD+R/RW 8x4x16x DVD-R/RW 42x32x42x CD-R/RW 2.4x DVD+R DL Dual......
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 30, 2010 | AOpen DUW-1608/ARR Chameleon 16x4x16x...
Hi, My Optiarc DVD RW AD 7530B doesnt read or play DVDS or CDs. it has power but when you click on E drive, an error comes up, that there is no disc
hey gues... we have some problem about my dvd/cd rewritable Drives model AD-7530B . it's my note book HP 520 can detect disk drive , but can not work anything . could you help me and give me information . how i can solution this problem ?... thank's
Jan 26, 2010 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
I have a Asus computer and my cd/dvd rw stop working. I can't watch dvd's or listen to any cd's I need to know what's up with my cd/dvd multi-recorder
First try a system restore back to the last date which you remember that it worked. If that doesnt help, you must find out what cd/dvd burning software is in your computer. It may have been corrupted. Oddly enough, you don't need drivers for the CD/DVD drives. They aren't even recognized unless you have a good non-microsoft burning program. Find out what burning software you have--download Belarc Advisor, a free program (Google it) which not only tells you everything in your computer, with model and serial numbers for hardware and all of your software (with their unique codes), but will also inform you if you are missing any needed Windows updates. Once you know what you have, if it came with the computer, you have to seek an upgrade at the computer manufacturer's website, as it may be a special program not related to the burning software purchased from the software manufacturer---go to their website for upgrades.
Mar 14, 2008 | ASUS (CRW5232A/QTWHT/G) CD-RW Burner
Dvd-rw dvr-k17rs ata with aspire 5610z
Hey Google AUTORUNGUI.dll Download It And Then Just Copy The .dll to Your Win System32 Folder Replace It.
SHOULD WORK...........................................
Comment If It Doesnt I Will Tell You Some More Solutions
And Leave Your PC Info With Operating System OtherWise Really Hard ....................................................................................
Jan 08, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
I need help getting dvd+rw drive operating
hi
go to nearer computer sales and support centre purchase a DVD R/W and if u have CD drive dis connect power cable and data cable then remove screws from cd drive then remove it fromyour cpu cabinate in same place insert your DVD R/W fix all screws,data cable and power cable.then connect all the data/power in backside of cpu if you r removed before otherwise again check all the cables and power on your cpu/moniter.after booting sucessfully your computer insert your nero cd which is given with your DVD R/W,cd automatically open then setup it one by one by soing instructions.after setup complete your DVD R/W is ready to read write CD/DVD.
thanks
Nov 12, 2007 | Computers & Internet
LG DVD Drive
the scsi and raid refers to sata hard drives or ide in a raid configuration. the dvd drive if on a cable on its own should be set at master, if on a cable with another drive then set it at slave, cable select doesnt always work as the motherboard cannot identify the ide source. Youe DVD drive will be listed in device manager under cd/dvd drives, click the + sign and if it's listed there, right click it and select uninstall. Restart the pc and see if it's reinstalled automatically, it should do, then be ready for use, if you still cannot see it in my computer check the drives ide cable and swap the drives over if necassary, if still not showing the drive needs to be replaced.
Sep 21, 2007 | Computers & Internet
Pioneer DVR-107D DVD±RW Burner Logo
157 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
