Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
The oven function (broil, bake, etc) knob does not light
Power is fine, temp control light comes on, fan works for convection, but the light adjacent to the oven function (broil, bake, etc) knob does not light. Oven does not work in broil or bake mode
  • Viking Master
  • 8,220 Answers
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Posted on Sep 09, 2009
Thermador smw 272 not heating via bake or convection. Light and fan work as well as broil and clean (microwave fine too). If I switch from broil and then to bake after heated, it will hit right temp and...
see if there is a bad solder connection on the bottom (underside) of the board just below one or more of the small black relay boxes. re-solder if you can or replace the whole board.
Jan 04, 2015 | Thermador Ovens
What is an EOC
Good Afternoon Friend, this is. Z. That's a great question.
The EOC (Electronic Oven Control) provides power for all oven operations (i.e. Bake, Broil, Convection Elements, Convection Fans, Lights and etc.) Hope this helps!
Aug 05, 2014 | Frigidaire Ovens
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
Jan 29, 2010 | Maytag Appliances 27" Electric Double Wall...
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Nov 25, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
441 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
