Question about HP Officejet Pro L7680 All-In-One Printer
Randomly prints multiple copies
Although only one copy is requested, the printer prints 2, 3, 4 (up to 6 copies).
HP Officejet Pro L7780 - All in one
Why does my HP OfficeJet L7780 print blank copy with the regular copy
This is normally caused by a driver issue. Check that your device driver is correct for this particular machine.
Oct 19, 2014 | HP Officejet Pro L7780 All-in-One -...
Good morning,am trying to fix a hp officejet pro l7780.It can't scan,copy or send fax.Could someone assist me please?
Does the fax/scanner light come on at all? If not, then that's the problem, because that's the only part that likely needs to warm up.
Sep 11, 2014 | HP Officejet Pro L7780 All-In-One InkJet...
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
WHERE CAN I FIND PARTS FOR L7780? I NEED THE PAPER HOLDER GUIDE FOR THE TOP PART AND THE PAPER HOLDER FOR WHERE THE PAPER FEEDS OUT AFTER BEING PRINTED?
Look on this link:
http://www.sparepartswarehouse.com/HP,OfficeJet-Pro,L7780,Printer,Parts.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP L7780 prints a vertical line down the right side of the page when I COPY or SCAN. It prints files perfectly. Can anyone help?
If you open up the tray on the printer you will see a diagram explaining how to clean a small blue screen. I did this with our printer and the problem cleared right up.
Jan 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Size Error: The specified custom paper size is not supported in the selected tray. I have a Hp Officejet pro L7780 All in one. I checked the default printer and paper handling and it all says letter...
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
