Question about Troy-Bilt® Briggs and Stratton Chipper
Troy Bilt Lawn mower manual - Troy-Bilt® Briggs and Stratton Chipper
  • 1 more comment
  • eric_seaward Sep 08, 2009
    6hp Troy Bilt self propelled lawn mower model number 34345 operating manual
    Require a operating manual for a 6hp Troy Bilt self propelled Lawn Mower model number 34345
  • Chuck
    Chuck May 11, 2010
    Are you trying to ask a question, making an offer or just making a statement?
  • 82 Answers
SOURCE: Where can I get an owner's manual for a Troy Bilt
Here: http://www.brentchalmers.com/
Keep all of those fingers out of the shredder!
Hope this helps, if so pls leave feedback, if not let me know!
Posted on Jan 25, 2010
boscia
  • 163 Answers
SOURCE: need Owner's Manual
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10001 online manuals are available there
Posted on Nov 30, 2008
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy Bilt Lawn Mower how to fit carburettor cable
Troy Bilt has a great website but you need to find your model number to use it.
Lawn Care Products Lawn Care Equipment from Troy Bilt
Sep 14, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
My troy bilt lawn mower does not want to start like it loses priming. Can I reprime manually
if it has a bulb pump it about 20 times if not you could spray a little starting fluid in the air filter or take filter off and poor a little gas in the carb
Aug 03, 2013 | Troy Bilt 5.5hp Self Propelled Mower
What kind of oil does my Troy-Bilt 12a-264u011 5.5 HP walk behind mower use?
You can check your manual but i would use SAE 30, if in doubt call your Troy Bilt dealer
Jul 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Need manual for Troy Bilt lawn mower 12ai867q011
Hi and welcome to FixYa. I am Kelly. You will need both your model and serial number but you can get it online directly from Troy-Bilt here:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1
Just enter your model and serial number and download the manual.
Thanks for choosing FixYa.
Kelly
Jul 21, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt® Briggs and Stratton Chipper  Logo
800 people viewed this question
Top Troy Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Paul Sikkema
Paul Sikkema
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
