Question about Canon PowerShot SX100 IS Digital Camera
Need to reset time and date every time I turn on camera.
One day I just turned on my camera and it asked me for the time and date as it did when I first bought it and it continues to do so every time I do. otherwise it works fine. what can I do?
  • 1,305 Answers
You need to insert a new date/time battery. It's one of those flat disc batts that fits in a holder on the side of your camera. Look for a battery compartment cover on the right side of your camera with the lens facing you... it should come open with your thumbnail... make sure to put batt in correct direction.
K
Posted on Sep 12, 2009
  • 2,126 Answers
The backup battery needs to be replaced. This small button battery (CR1220) provides the power for your camera to 'remember' settings when you change or remove the AA batteries. Instructions for changing this battery are in the manual on page 191 (US version of manual).
You can view/download the manual here.
Posted on Sep 10, 2009
Date/Time resets every time i turn on camera.
Hi, yes, there is a small coin memory battery, usually something like a CR3032 lithium battery. Turn off the camera and insert a new 'coin' battery (correct side up). Close battery cover, turn on camera and go to menu and set time and date. It should remember the time and date for a year or two, provided you put a regular battery on the camera on a regular basis. Also note, some older Sony cameras allow you to set it so that it shows only the date for the 1st 5 seconds when you first turn on the camera that day, then shuts it off unless you want it to superimpose the time and date on the video. Good luck, and let me know if this solves your problem. John
Jan 17, 2012 | Sony Handycam HDR-XR520 High Definition...
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
We can turn on the camera, but the OK button does not wok.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 27, 2009 | Kodak EasyShare CX7330 Digital Camera
Asks to reset date and time evertime I turn it on
Hi there.
Yes there is a soloution to your problem, there is an internal lithium battery insider the camera that keeps the time and date, its this battery that needs to be changed.
Good luck and thanks for using FixYa!!
May 12, 2009 | Nikon COOLPIX S710 Digital Camera
Cannot turn date stamp off and date keeps resetting
Try removing battery from camera then wait 10 seconds before installing. This action resets camera.
If no work, locate your camera software version. Procedure should be in manual, else could probably find it in a google search. Then locate latest version with a google search, or panasonic camera website, or call to customer service and ask.
It you do not have latest version, ask customer service how to download it.
Jan 20, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
I can not turn the day/date feature OFF on my Hitachi DZ mv550 camcorder
The instructions says there is a rechargable battery in the camera that maintains the date. It suggests that if the battery is exhausted the date and time will be reset (no definition of reset). It further says to connect the AC adapter/charger at least once every three months for 24 hours. You might try not using the adapter for three months and seeing if reset means no date/time at all or just 00/00/00. Steve
Dec 03, 2006 | Hitachi DZ-MV550 DVD Camcorder
Canon PowerShot SX100 IS Digital Camera Logo
339 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
