i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
My drive belt fell off the large wheel. I placed it back on and moved it all the way to the front of...
(More)
My drive belt fell off the large wheel. I placed it back on and moved it all the way to the front of the drive but when I turn it the belt moves back off of the large wheel (to the part closer to the tub) How do I fix this. Yesterday it started to make a thumping noise whenever the machine ran and then today it stopped spinning and I found the drive belt off.
Thank you
