Question about LG Washing Machines
LG washer wont drain or spin
Please help
  • cjmrdc Sep 08, 2009
    It has power. The door is closed. It runs through the wash cycle fine ( the drum moves, etc.) when it switched to the rinse cycle it just makes a rattling noise and it wont drain out or spin. I ran a large load yesterday and it came up with the uneven load error (I think) but apparently it was more than that. I tis about 5 years old. Model #WM0532WH LG
  • Jose Pino May 11, 2010
    Quite difficult to help with more information. The appliance have power? Closed door? What it does, what it doesn't do? Could you explain more about the failure, age of appliance, model number?
  • 139 Answers
The problem is this, The machine wont spin until it sense that it is empty. So your solution is easy either a faulty pump that wont drain the water from the machine or a blockage in the the filter. There should be a filter at the front behind the kick plate at the bottom of the machine just check to see if you have something stuck in it before you go changing the pump. The easest whether its the pump or a blcokage is to disconnectthe waste pipe and drop it to floor level if the water comes out the machine then its the pump if it does not then its a blockage .
please rate if it helps
Posted on Sep 09, 2009
8 YEAR OLD LG FRONT LOAD WASHER WONT SPIN OR DRAIN
If the washer won't spin the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Aug 29, 2014 | LG WM1814CW Front Load Washer
Washer wont spin
Sounds as though the idler on the back of the machine is seized.Remove the back panel and possibly free it up or replace it.
Dec 18, 2012 | LG WM2487H Front Load Washer
Washer wont spin and makes a clicking noise
I have a LG front load and it won't spin or drain... Can u please help me
Jul 01, 2012 | LG WM1814CW Front Load Washer
My lg washing machine is making a lot of noise when it is spinning and it wont spin out the water to good
Hi blare131,
I believe there may be a foreign object in you drain pump filter, this must be removed (Should solve both issues)
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 17, 2011 | LG WM-2277HW Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
My front loader washer gets stuck on its last spin and wont drain properly. I am trying to wash a comforter and blanket. This is the 1st time its happened. Thank you
You may to mention the brand and model of machine. Mine is an Lg, I just shut off machine. Turn it back on and then press the no spin and start, this drains the washer. You may have too much clothes in the machine.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
heatman101
Oct 12, 2010 | LG WM1812C Front Load Washer
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
Washing Machines Logo
160 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
