Question about Panasonic TH-58PX60U 58 in. Plasma HDTV
Power light flashes on & off. Had an electric storm and power outage. Set wil notturn on. 58in. plasma
  • angieanddrc Sep 09, 2009
    Solution didn't work but I'll have to contact a local flat panel service tech - IT BLINKS 10 times -one hour off didn't help. thanks
  • 2,200 Answers
The set will not turn on as it has detected an electrically unsafe condition. This may be a result of a powersurge around the time of the outage or it may be because an electrical problem has occurred within the circuitry of the set itself. The set has effectively entered 'Safe Mode'.
The source of this problem on the Panasonic Plasma is relative to the number of blinks on the power light. The number of blinks gives an error indication as to exactly where in the circuitry the problem lies.
A reset can sometimes be achieved by disconnecting the power altogether from the TV for a period of one hour at the circuit breaker.
This simple reset will be enough to resolve the issue on many occassions. However if damage has already occurred to the internal circuitry it will have no effect.
If the problem persists after disconnecting the power as outlined - the problem is due to damaged circuitry inside the TV. This is not a user serviceable issue and the only thing you can do is count the number of flashes and contact a Panasonic Service Centre to request a repair.
It will assist the technician if you have the information on the number of flashes already at hand.
To locate a Panasonic service centre near you have a look at this link
http://www2.panasonic.com/consumer-electronics/support/Contact-Us.4
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 08, 2009
  • Radio Code Pro
    Radio Code Pro Sep 09, 2009
    Sorry to hear that the problem is persisting. Thank you also for accepting the solution/advice.
    For your further information, I would like to add the following as there is one further step you can try that is specific to the 10 flash error before calling in the tech.
    The 10 flashes error is fairly common on these TVs and in some instances this particular error can be associated with a problem reading from the HDMI connectors attached to the set. You might just get the set to power up if you temporarily remove all HDMI connections - then hold the power button for 10 seconds on the set and as I say it might just power up.
    You can then reconnect the HDMI leads and if you are lucky the issue may be resolved. It is certainly worth a try!
    However - be aware that even if this works - this may only result in a temporary fix. If the issue appears again or is still not resolved then there is a definite component malfunction. To help your tech when he calls - the components listed by Panasonic as associated with the 10 flash error are;
    Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS (obviously these are not user serviceable)
    I do hope this helps and I thought I would add this in given that this procedure of disconnecting HDMI leads is particular to the 10 flashes error. I also hate to see anyone have to call and pay for a tech if it can possibly be avoided!
    Many thanks for using FixYa.
My panisonic 58in plasma TV model number th-58px600u is giving me a flashing code of 10 blinks what does that mean
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Mar 27, 2016 | Televison & Video
SAMSUNG 52 IN.LCD TV, WILL NOT COME ON, THE POWER & LIGHT BUTTON CLICKS ON & OFF CONSTANTLY
Sounds like it may have taken a surge. Did you unplug the set? Try that and give it 5 minute time out before powering back up.
Did anything happen before the problem started like a power outage? big storm? Brown out condition (that's when power is low due to excessive AC use in the summer and the lights grow dim etc - very bad for electronics and motors too)
Do a little more detective work and post your suspicions and findings.
Worse case scenario is there is something wrong inside your set and may need a visit to the repair center. How old is it?
Hope this helps.
Aug 26, 2012 | Samsung Televison & Video
Can't get channel manager to come up. Can't change channels. Electric went out from a thunder storm. Transformer hit by lighting. Now can't get channel manager to come up and can't cha
If you have not tried it: UNPLUG THE SET FOR A WHILE then plug b a c k and see if helped-----what can happen if power outage is microprocessor in set gets confused.
Let me know if questions or if this helped.
Mar 23, 2012 | Hitachi P50V702 50 in. Plasma HDTV
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Jun 18, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Panasonic TH-58PX60U 58 in. Plasma HDTV Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
