Question about LG Incite Cell Phone
Having problem with screen. Since phone got left in sun once the screen won't calibrate properly. I let it sit for a couple weeks now it calibrates fine and then 10 minutes later it points to 1 inch to the left of anything I touch?? I assume it is the Digitizer screen. How does the phone come apart to replace the top screen. I have a parts one to try pieces from.
    Sergeant:
  • 324 Answers
Take it to a tech support close to you
Posted on Sep 08, 2009
Hi, I am having trouble with my LG Ku990i mobile phone, the touch pad calibration won't work & screen has frozen
Touch screen problem
If your touch screen is not working, there are just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jul 13, 2011 | LG KU990i Cell Phone
Lava a10 touch screen is not working properly
If your touch screen is not working, there's just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
Jun 17, 2011 | Cell Phones
I think my screen needs calibration. i left under the hot sun and the screen is impossible to click the right choice especially the upper part of the screen . please help
i would say you will need more than calibration , you will probably need a new touch screen. The hot sun has probably distorted the touch screen which is why it no longer responds correctly
Apr 07, 2011 | Tomtom XL 340S Car GPS Receiver
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
Hi! The touch screen on my Garmin nuvi 660 is not working. On boot up I can't get past the reminder to update map data screen. I have updated the unit software and tried to recalibrate the screen. As is...
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, screen calibration do not just work once you do it, you have to do it over time for it to work. Ensure you are calibrating properly. These are the proper steps to follow when trying to calibrate the screen:
Try this repeatedly till you get it to work. If it does not work, then it means there is an internal problem that need to be checked by a repairman.That should do the job for you.
hope this helps.
Dec 26, 2010 | Garmin Nuvi 660 GPS Receiver
Calibration not working wen i push buttons 1 4 7 * sos 3 6 9 # works so nothin on left of screen works so i cannot access phone menu to reset
Hi,what makes the calibration not working.is because the touch screen of the phone you are using is not functioning properly. And you will need to replace the touch pad of the phone for it to work properly again.
Sep 25, 2010 | Samsung Cell Phones
EnV Touch VX11000 Cell Phone: I am having problems with my touch screen. It work...
once again try to calibrate if that won't work then restore your setting factory setting but before resetting it to factory setting take backup of your data
May 07, 2010 | LG enV Touch VX11000 Cell Phone
Touch screen of samsung star doesn't work properly.
all u need to do is to improve ur calibration
go to
MENU>>SETTINGS>>PHONE SETTINGS>>CALIBRATION
improve ur calibration but prefer to tick with thum
Sep 26, 2009 | Samsung SGH-L700 Cell Phone
My TX's Top Left quadrant of the touch screen has lost "sensitivity" but generally the whole screen is out of calibration.
have you tried using the built in calibration function on your phone? calibrate it again and again untill you can touch each point just once. if this doesnt work you may have damaged that part of the digitizer and you will have to replace the screen.
Jun 12, 2009 | Palm TX Handheld
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Sep 10, 2008 | Nokia 6300 Cellular Phone
LG Incite  Cell Phone Logo
94 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
