Question about ION Audio Audio Players & Recorders
The volume coming from the stereo is very low. what gives?
  • 3,153 Answers
Check the preamp switch. some have a built in preamp which may be needed when connecting to some equiment
If connection via PHONO cables to a PC then it should be on
Some older hi-fi equiment may have two sets of PHONO input one for low inpedance and one for high
Posted on Sep 08, 2009
  • Project NOMAD
    Project NOMAD Sep 10, 2009
    So did you find out why ?
Volume coming from tv is so low
you have to goto setting and set the speaker to tv if you have a newer tv
Mar 28, 2014 | Denon AVR-1513
Aux in volume is low on aiwa stereo
Use the forward keys when in AUX , it gives u a 5 step volume level .
I have tried it and it works.
Feb 08, 2014 | Aiwa Audio Players & Recorders
No sound comes out of speakers
All speakers?
Check the operation and connection of the volume control on the stereo. Unmute any mute function. Failing that, pull the stereo out and check the connections on the rear. If they also seem fine, then take a multimeter and check for voltage to the speaker wires from the stereo. If you don't have voltage (it will be low anyway, but it should be there) then the stereo is dead.
Nov 15, 2012 | 1987 Toyota Camry
Low volume on my panosonic
If you are using a cable box or other device upstream, look into it's volume. Typically source units would like to be 30 to to% volume, with the tv or stereo being the final control. What happens is the source volume gets turned too low, and then the final unit (tv or stereo) has to have so much volume to hear anything, distortion and poor sound result. Start with both midway and you should be good to go.
This presumes that you toggled any buttons that said mute or attenuate...
Oct 26, 2011 | Panasonic TCP42C2 42 in TV
My Alpine MRP-M650 Amp is acting up. When I start the car, if the volume is at low, the subs don't work. But when I turn up the volume, they eventually kick in, then I can lower the volume. But when...
There are a lot of things that could cause this issue ...
1. Your amp requires more power than it gets when you start your car, and needs to charge up before it can work. If this is the case, you should be able to give your stereo about 5 minutes to warm up at low volume and it should come on. This happens a lot with amps with built-in capacitors (capacitors give you stunning, instant kick when working, but require a bunch of power to initialize). If you wire a bypass switch for the power to your amp and bass components, you can turn it on separate from the rest of the car and allow it to charge before you start your car (just be careful to turn it off when you are going to be away from your car for a while since this will allow your system to drain your battery).
2. Your amp might be set incorrectly for handling the system you are running. If your Ohms do not match up exactly (8 ohm speakers with a 4 ohm amp -- it's the "Impedance rating") then the system should not work at all, or should burn out the amp ... but with a jury-rigged system it can work. If this is the case, I recommend getting a new amp that matches your speakers.
3. Depending on the amp, there might be a volume-based cutoff that is working improperly. Turn on the car with the stereo at low volume. While the speakers are still not working, check to make sure that the amp has power, and seems to be functioning correctly. If everything seems like it's on the up and up, but the speakers are not working, try changing the volume-filter options on your amp.
4. I put this last because it seems like you know what you are doing with the system setup, but it is possible that you have a bad connection between the speakers and the amp, or between the stereo and the amp. There could be a loose connection somewhere (either inside the amp, between the amp and the speakers at the jack, or between the stereo and the amp at the jack). If this were the case, everything would look perfect from a visual inspection, but there could be a tiny space, or corrosion in a connection. Turning the stereo up to a high volume could then bridge this short circuit, and the electric force could magnetize the connection shut, allowing you to then turn the stereo down with the working connection. The best-case scenario here would be an external wiring issue, where you can clean any corrosion off the connections with an eraser, and reconnect everything tightly fixing the problem. The worst case would be a short WITHIN the amp, which would have to be repaired by someone with a lot of time and a circuit tester -- in which case you might be better off trading the amp in for a new one.
May 26, 2011 | Alpine MRP-M650 Car Audio Amplifier
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
F61 pops up as a error code on stereo
try starting out with volume low. And check to make sure no wires are touching I believe this is a circuit protection code
Jul 07, 2009 | Audio Players & Recorders
135 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
