Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 error whirlpool cabrio wtw6600sb2
I had this washer for a little over 2 years and I am now dealing with the F1 ****. I called whirlpool maybe three months ago and they said that there is nothing that they can do the it being out of warranty. I called whirlpool again after reading some of these post. The lady that was helping me first said that there is no recall and no issues have been reported on this unit. That's when I told her that I had been online researching this and found numerous people with this issue. Then she put me on hold and comes back and says that, if I would pay half price for the part they would have a tech to come out and look at the washer, then he would tell me what part I need and I was to call back and let them order it for me. It didn't seem like they were going to budge anymore than that so I said fine but I really don't think I should have to pay anything because it is an issue.
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%#@
Posted on Sep 21, 2010
4 Suggested Answers
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: Cabrio Washer F1
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$&^#$@%
Posted on Sep 20, 2010
  • 269 Answers
SOURCE: Has the Cabrio he (whirlpool) model WTW6600SB2
Sadly no there isn't i did the research for ya. And wrote to Whirlpool Co. I will keep you posted.
Posted on Dec 26, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Lid will not lock and just click click click (trying to lock but can't)..then "lid" is displayed and then f1.. sometimes I can (after trying different things finally get it to lock) Something like this...
    Hi
    Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    When we try to wash a load of laundry after a couple minutes we get the code F1 show up and the wash cycle turns off. What is F1 and how can we fix it so the Whirlpool Cabrio washer will work again?
    We have had the same problem for three years. We are only using this washer about 4 months a year. We has two service calls..no help. We had to baby sit the washer just like all the other posts, pressing pause about five or six times or more.
    Well, I read the posts & that Whirlpool had fixed this problem, paying for parts & labor..we called..they sent a repairman. It took him 20 minutes, he asked if this was the code, said he carried at least three of these parts & now..the washer has been running fine. three loads so far.
    So, call them, tell them the problem & it will be fixed at no expense to you..or should be.
    Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code on cabrio washer
    CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
    WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
    T W
    Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
    Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error on Whirlpool cabrio
    it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
    Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    510 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
