Question about Kenmore Washing Machines
Will not release water - Kenmore Washing Machines
  • 15,935 Answers
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Water on drivers side floorboard . Why?
If you have a sunroof it could be the drain that follows the front pillar letting out under the front fender. These hoses are known to plug and crack open releasing water into the floorboards.
Driver side door check along top and front edge for tears or twisted looses sections. Internal to the door water can drain down along the window and is released outside the door seal. If the bottom of the door has the opening that releases the water plugged then water will drain over into the floorboard.
Jan 06, 2016 | Cars & Trucks
Water leak electrolux
Good Morning atgltd,
So I understand that your water dispenser continues to release water for several minutes after pouring a glass of water and that it also randomly dispenses water. It sounds like something could be going on with either the dispenser module or the water actuator. Give the refrigerator a hard reset. You can do this by either unplugging it or by switching the breaker off that it is connected to. Leave it off for 3-5 minutes. Connect the power back, and if you are still having the same troubles of the dispenser releasing water, I would suggest that you contact a local authorized technician to see what exactly is causing the water to continuously dispense.
-Best Regards-
Jan 24, 2014 | Frigidaire FRS3R5EMB Side by Side...
PRESUER VALVE KEEP LIFTING WHENWATER HEATER IS RUNNING
If water is exceptionally hot, the TP will release water.
Is water hotter than normal?
Or TP will release water when TP has gone bad.
Replace TP and see what happens.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Sep 17, 2012 | RTO Atwood DSI-RV Water Heater-6 Gallon
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
Leaking water
Need more information as to type of water heater
Have you checked to see if maybe a rubber seal is cracked or worn on your elements?
also check to see if its not simply releasing excess heat from the pressure release valve which in turn would have water around the water heater...Temperature may be too high which causing unit to over heat and release excess pressure....or it could simply be faulty
out of the 100 or so I've found its the water heater itself has developed a leak within itself which would need to be replaced due to corrosion and age.
Dec 27, 2010 | Rheem Water Heaters
Pop off valve releasing water. House pressure between 50 and 60 lbs. Plenty of hot water, set at 135 degrees. Not a lot of water but still release water regularly.
A build up of minerals in the water can cause this. You'll need to replace the pressure release valve. If your a DIYer it's not a nery difficult job as long as you make sure you get the exact replacement valve and take the necessary precautions to relieve tank pressure before beginning.
Feb 22, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The unit will not release water.
The water release probably has the hose pinched shut. Storing it with the trigger depressed will eliminate this. You'll have to find the spot, where the hose gets pinched, to shut off the flow and turn it 90°.
Jul 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Removal of water pump
Removing alternator drive belt, refer to Engine.
Release the belt pulley from the water pump.
98758195
Drain coolant.
Release water pump.
98758196
Insert two M6 screws in water-pump thread and press out water pump evenly from gear case.
98758197
Installation:
Replace sealing ring.
May 25, 2009 | 1996 BMW 318
CAN NOT REMOVE WATER FILTER FROM PLASTIC HOLDER
it will also state to turn of the water supply and release any pressure
Jul 02, 2017 | Maytag MSD2651 HE Side by Side...
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
