Question about Hifonics BX2200D Car Audio Amplifier
My bx2200 cut off as soon as it was turned on and started smoking?
Took the bottom cover off and can see soot an char on a couple of the black parts that are mounted down the side of the heatsink. there is about six on each side of the amplifier
    Sergeant:
    Champion:
  • 231 Answers
These are the trasistors..The ones closest to the power connectors are probably the ones for power supply and or 15 volt regulators..The rest are for amplifier section.Im guessing all except regulatos will be MOSFET transistors .If you are to replace them ..Stick to original parts..You can probably find these at mcmelectronics.com or mouserelectronics.com Just give then the numbers on transistors .Also make sure all other parts around shorted parts are okay before you install new parts..
Posted on Dec 09, 2007
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
Nov 22, 2017 | Beko Wm & Wma Models Washing Machine Motor...
Hotpoint washer won't spin or agitate and has black soot - is clutch out?
The motor coupling is attached to the shaft of the motor. The "soot" is probably the result of the coupling shredding prior to failing
Oct 09, 2012 | Hotpoint Washing Machines
Black smoke from exhaust, rough idle, black soot on plugs
signs of a bad fuel pressure regulator-- the vehicle will run rough, the engine will not start ( usually in the mornings,) many times engine starts but stalls shortly after starting. a bad regulator can result in fouled plugs. replacement is only cure. 1- black soot on plugs-2-black smoke from tailpipe-3- running rough-4- stalling, good-day! repost if need be.
Aug 10, 2011 | 1994 Suzuki Sidekick
Wow great site! Problem with my 600 series penguin Unit started acting strangely last weekend, smelled something electrical when I first turned it on. but then cooled fine. This weekend DW took it out for...
Hello my name is Heath it will be my pleasure to assist you. What you are looking at is the start capacitor for the motor a $7 part at any HVAC supplier. If it is leaking it is definitely bad and needs to be replaced. This gives the compressor a boost on start up and drops out of the circuit after the compressor is running.
Jun 13, 2010 | Dometic Rooftop RV Air Conditioner
My Chevy Tahoe started blowing white smoke from the tailpipe. What could be some of the reasons it's doing this.
Only two reasons for this first is its below 0 outside the next is blown head gasket. Now thats WHITE smoke.ONLY.If it smells sweet like anti freeze that confirms head problem. black smoke is fuel, blue smoke is oil. sorry hope this helps TIM
Feb 18, 2010 | 1997 Chevrolet Tahoe
Exhaust smoke at start up
It means that the system is running rich, in other words too much fuel.
Try checking your air filter--make sure it is not dirty. Also check for a plugged air intake hose. Enough air is not getting into your cylinders for the proper air-fuel ratio.
If it has carb, the carb float is too high or sunk.
Mar 27, 2009 | 1991 Ford F150
It sounds like the power supply transistors have failed. You'll need to pull the clamps and get the numbers off of the transistors. It's also possible that the 47 ohm gate resistors have failed. After removing the old transistors, you need to check the resistors individually.
Since you're new to repair work, read the following page.
Basic Repair Introduction
Post the part numbers if they are incomplete and you can't find the correct replacements. mouser.com is probably the best place to buy small quantities if you're in the US.
You also need to check the output transistors to see if any are shorted. If they are, the repair will be more difficult (especially if there is damage to the driver board).
Feb 15, 2008 | Hifonics Brutus BX 1605D Car Audio...
Hifonics BX2200D Car Audio Amplifier Logo
106 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
