Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Frost collecting inside freezer and motor constantly running
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Freezer fan stays on constantly. temps ok in both sides. will this cost much more electricity and should i really worry about it.
If the freezer fan is running constantly, and things aren't too cold in either section, it means the frig thinks its not cold enough to shut off, so it runs trying to get to the proper temp. you have control set at. Check for any frost buildup on freezers back panel inside freezer. If there is you have a defrost problem.
Oct 01, 2011 | Hotpoint HSS25GFP Side by Side...
I think my amana fridge is going out the fridge isn't keeping food cold and the motor is always running
hmm, is the freezer ok? what motor is constantly running? is there frost on the back side of the freezer?
Dec 18, 2010 | Amana Refrigerators
Refrigerator not cold, running constantly, freezer was cold but noticed its not as cold. cleaned everything in front, pulled it out and looked at back, no frost on everything, fan is running, not sure if...
This could be cause by several different problems. Here they are. Not enough R-134a freon. Severe frost behind back panel (inside freezer section) Conderser motor not running or running too slow to cool off compressor. Very dirty condenser. Excessive heat wll cause the compressor to over heat and warm up frig. It take about an hour for it to cool off and come back on. if you find out this problem let me know
Mar 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi! My kelvinator FN360 frost free freezer's motor is running all the time and it is not freezing inside properly.Occasionally, there is a pop coming from the freezer (most of the items are frozen though)...
check your door seals. warm air leaking in can keep it from reaching it's temp. also, the condensation will collect on the evaporator coils causing them to freeze up. when they do, there is no air flow to cool the rest of the fridge, so the compressor will run constantly trying to reach the set temp. empty it out, thaw out the coils, and check your door seals for leaks. if it still happens, you might have a slow freon leak.
Nov 10, 2009 | Freezers
Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refridgerator too warm freezer ok running constantly
could be your evaporator fan which is located in freezer.If you dont hear it blowing when compressor is running then it is evap. fan motor.if you see alot of frost building up on back panel inside freezer then you have a defrost problem.check heater and thermostat to see if they are good or bad.the thermostat will usually pop apart but not always it is located at the top in back of freezer on coils.it will have two wires going to it.good luck.and unplug first.
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
153 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
