Question about Sony VAIO PCV-RS310 PC Desktop
I own a sony vaio pcv-rs310 with windows xp home edition. everything is factory except new 1gb kingston technology ddr ram, evga nvidia geforce 9400gt 1gb ddr2. Everything worked out fine until I unplugged vga cable and plugged it back in with a dvi to vga adapter while the computer was still on. Now when I turn my computer on it just has the windows xp startup screen but nothing after that (sign in screen). I have checked the new video card (mentioned above) nothing is wrong with it. I have also restored the factory settings in BIOS and that did not work. Also, I had to disable the intel extreme graphics card that came with the computer so that the new one would work properly, so I can't use that. I was just wondering if there is some kind of command in the advanced settings menu (F8) that I could enter to either reset the graphics output or to re-enable the original graphics card, or anything else possibly. Thanks to whoever can figure this out!
  • skulls138 Sep 09, 2009
    Hello Niveous, well I tried to reboot in safe mode but that did not work either, I also went ahead and tried the "last known good settings" option. That didnt work either. Do you know of anything else that might work? I was thinking there is some kind of command prompt I could type in the "reboot with command prompt" option. Thanks for the help so far.
  • 58 Answers
You can hit F8 and select boot in safe mode. One in you can try and reistall driver or set video back old way
Posted on Sep 08, 2009
Pcv-rs310 video controller
Try this http://esupport.sony.com/perl/model-home.pl?mdl=PCVRS310
drivers and software..Or you can click on support and scroll down you will see vaio detect my computer
Apr 14, 2013 | Sony VAIO PCV-RS310 PC Desktop
Windows XP Home Edition (Version 2002) will not load, bought "Iolo's System Mechanic", but it says not to proceed if the system is 64-bit...data will be corrupted. How do I find out if my Sony...
If it is running Windows XP Home Edition (Version 2002) it is not 64 bit it is 32bit. 64 bit only came in Windows XP PRO 64bit and Vista 64bit and Windows7 64bit
Feb 12, 2011 | Sony VAIO PCV-RS630G PC Desktop
I would like to set my Sony Vaio PCV-RS310 back to factory setting. Please help.
Hi and welcome to fixya,
After making a back up of your most important files, restart the computer and press F10 to start the recovery console. Follow the instructions on the screen and it should take you to a Full Factory Setting..
Hope this helps
Jan 02, 2011 | Sony VAIO PCV-RS310 PC Desktop
I have dell gx 260 with 2.4 ghz nd 1gb ddr ram with nvidia geforce fx 5200 can u name any graphics card which will be gud enough than geforce 5200...nd agp plz..
You need an AGP 8X graphics card for one.
AMD ATI Radeon series:
1) Better: XFX Radeon HD4650
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4914257&CatId=2234
A) 1GB (OR 1024MB) of DDR2 graphics ram memory
B) 128-bit bandwidth memory interface
C) 320 Stream Processors
D) 600MHz Core Clock
E) 800MHz Memory Clock
F) 55nm process technology
3) Best: HIS HD4670
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=2234
A) 1GB (Or 1024MB) of DDR3 graphics ram memory
D) 750MHz Core Clock
E) 1600MHz Memory Clock
Likes POWER! Better install a 500 Watt power supply, to keep up with the power needed for this baby!
The GX260 supposedly has a 250 Watt PSU. (Power Supply Unit)
Back in the day this PSU was made, the PSU manufacturer 'fudged' the maximum rated wattage.
Actual is more like 60 percent of what is stated.
175 watts!
The above is just IMHO about graphics card choice.
(I have motherboard's with a PCI Express x16 slot, using the PCI-E 2.0 technology.
I use Nvidia graphics cards)
Oct 16, 2010 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Problem installation video card
Hello Virna, i have that exact graphics card and dell GX270 desktop here at home, tho it has been awhile since i removed the Nvidia PCI card for a more favorable AGP card. From what i remember, first check your BIOS (hit F2 on startup) and select integrated devices, scroll down and make sure your default video output is either PCI (if available) or AUTO) exit saving changes. If that yields no result. Plug in a second monitor to your old integrated video output, if you can view windows after bootup from there, then you can install the proper Nvidia display driver for windows Xp (available here: http://www.nvidia.com/object/winxp_175.19_whql.html ). After installing, right click on the desktop, select properties, display settings tab, and make sure the Geforce card is the main monitor and the desktop monitor. Click apply, unplug the integrated VGA output, and restart. Hope this helps.
Apr 03, 2009 | Evga nVIDIA GeForce FX5500 Video Card,...
Sony Vaio sound...
Adam,
The sony VAIO Pcv-j200 only runs with Windows 2000, windows Me and windows xp. The current operating system Vista on your computer right now will work but some of the features of it may not. The link below shows all the drivers for your unit for diffent operating systems (not vista). What you can try to do is to download the audio driver for windows xp
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVJ200&LOC=3
Jul 05, 2008 | Sony VAIO PCV-J200 PC Desktop
Sony VAIO PCV-RS310 PC Desktop Logo
231 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
