Question about Lexmark X5495 Printer
Printer has cartridge error for lexmark error #1203
  • 624 Answers
SOURCE: Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Posted on Jan 20, 2007
Printerguy
  • 31 Answers
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Posted on Aug 21, 2007
JackHeath
  • 1049 Answers
SOURCE: Lexmark x3350 cartridge error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
Posted on Jul 28, 2008
s_4u_11
  • 535 Answers
SOURCE: lexmark printer x5470
remove & reinstall your printer driver & try to print
Posted on Jan 12, 2009
d2704
  • 101 Answers
SOURCE: Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Posted on Mar 07, 2009
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
How to fix error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cartridge error 1203
or
Hope it will work for you take care all the best Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One InkJet Printer
or
Jan 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Lexmark X8350
or
Aug 03, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X5495 Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
