Question about Acer Aspire 5100 Notebook
No power on battery or ac - Acer Aspire 5100 Notebook
    President:
  • 1,187 Answers
You may not have provided enough info ... but try this:
1. Remove battery from laptop
2. Plug in A/C adapter
3. Turn ON laptop with no battery in it.
4. After Windows settles down, insert battery and let it charge for several hours.
Hope that helps!
Posted on Sep 08, 2009
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
I have a Dell Latitude D800. I want to run it on AC power. Do I have to take the battery pack out of it before I ru it on AC power?
Hello Paula, Hi Never remove the battery out when powering with AC, your Dell will get busted, run ac with the battery. The AC power produces a voltage above the normal operating voltage of the Dell, the over voltage is for charging the battery and powering the DELL, if you remove the battery, the over voltage will bust the laptop in seconds. So operate the laptop with AC and battery.
Feb 11, 2011 | Computers & Internet
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
Is it alright to keep the battery in the battery compartment even if it's fully charged or I have to remove it when using AC power?
There is no need of removing the battery from your notebook. Only thing you have to remember is dont use your notebook so much in ac power it can reduce your battery life. Use your laptop in battery till the battery power gets drained and then connect to ac power for charging and at the same time use your notebook in ac power. But avoid much connecting your notebook in ac power. It helps in maintiaining your battery stable.
Aug 31, 2010 | Acer Aspire 5610-4648 Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Power source not charcing battery
Its not the battery, its AC power source providing your problem.
Check if AC connector goes in as far as it should on your laptop, check so you dont have a weak link on the cables on the AC. My guess is that the power sorce or the cables on is defect someway.
Nov 19, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire 5100 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
