Question about Equator 23 in. WB72 / BB72 Built-in Dishwasher
Equator 72 stainless model
Where can i buy replacement utensil caddy for this model. Equator wants way too much money and the bottom of the caddies just broke away after 2 years. Can't I get generic ones somewhere?
2 Suggested Answers
  • 19396 Answers
SOURCE: Parts needed
Where are you located?
Posted on Mar 06, 2008
  • 338 Answers
SOURCE: Silverware caddy
goto and use the dwb number to find the baskets..
Posted on Mar 13, 2009
0 characters
1 Points
My Maytag stainless steel dishwasher utensil basket has 2 holes in it. I would like to buy a new one. Can you help me ?
Try either or Provide them with your dishwasher model number. Once you get the part number for the utensil basket, then you can go to eBay and usually find one cheaper!
Feb 15, 2015 | Maytag Dishwashers
Brand new KitchenAid KUDE40FX door won't latch any more and thus won't start.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel:
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
Jan 11, 2013 | KitchenAid Superba KUDE40FX Fully...
Silverware caddy
Mar 13, 2009 | Dishwashers
32 inch dishwasher...
hello Welcome
I believe Ge makes one to go under a sink!
And that's the only one! that low.
Thank you Huum
please leave a solved rating before you sign off
Dec 07, 2008 | Equator Dishwashers
Parts needed
Mar 06, 2008 | Equator SB72 Built-in Dishwasher
Replacement hose connection for Equator 3500
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website and also place the order online.
Jan 19, 2008 | Equator 23 in. WB72 / BB72 Built-in...
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Equator 23 in. WB72 / BB72 Built-in Dishwasher Logo
16 people viewed this question
Top Equator Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Equator Dishwasher Expert? Answer questions, earn points and help others
