Question about Dynacraft Cycling
Have dynacraft 20 in trouble maker trying to remove rear bike tir
Have dynacraft 20 in trouble maker trying to remove rear wheel only one gear removed the two bolts but the wheel does not pop off so I can remove the tire, also the chain will not disengage
thanks
teqkng
  • 20 Answers
SOURCE: removal of sprocket and gears from rear tire for replacement
A special sprocket removal tool is required usually only $20 to $30 bucks at a decent bike shop.
Posted on Jan 31, 2009
  • 1138 Answers
SOURCE: Dynacraft Slumber Party 20 inch girls bike
Make sure you follow the directions carefully. You might try leaving the flat washers out or substituting thinner ones. Worse case you will have to go to a bicycle shop and purchase a longer axle. Make sure you keep careful track of how you disassembled it and take pictures or make drawings. The hardest part with replacing an axle is getting the proper resistance on both sides so the bearings don't bind. Check www.sheldonbrown.com for some helpful articles.
Posted on Aug 03, 2009
  • 11 Answers
SOURCE: My Mongoose "Gavel" BMX bike's rear wheel catches when I coast.
has the bike been in an accident recently? you can flip it over and spin the back wheel to make sure that wheel is "on center". if the wheel is not bent then u can just unloosen the back wheel then re-align to the center and tighten.
Posted on Jul 29, 2010
  • 70 Answers
SOURCE: where do I find a replacement tire for a barbie
Its either a 12" or 16" tire replace with any tire you like in that size
Posted on Aug 16, 2010
SOURCE: Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
Why aren't gears in sync with chain?
You have to set up sync. I could write it here but go to shimano.com and there are brilliant videos that talk you through gear sync. Very user friendly. No prior knowledge needed.
Mar 15, 2016 | Dynacraft Boys Magna 20" Invader Bmx Bike
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
I purchased the Dynacraft hot wheels 14 inche bike at Toys R Us. It is impossibe to tighten the revving handle bar. Should I return it. cgrigoli@aol.com
Yes. Exchange it for either a built bike or another one and try again.
It should be a fairly simple clamp that goes around the bars with a bolt and nut to secure it and tighten it down, if these don't work then the bike is useless and unrideable
Dec 27, 2010 | Dynacraft 16" Boy's Wheels Bike
20 inch Slumber party bicycle will not accept training wheels? Rear threaded axle is not long enough to allow for training wheels (that i cna find)
Yes you can add training wheels to this bike. The origional axle is too short, however, if you are mechanical enough, you can remove the axle and buy a longer one. I did this for my daughters bike, and for abot 5 dollars you can pick up a longer axle which will accept training wheels. But be warned, there are several bearings and you need to place them back in the correct position or the bike will not work.
Dec 27, 2010 | Dynacraft Cycling
Moto frenzy rc bike. fully charged. rear wheel won't turn. front will go left/right.
I also had this problem during christmas. The bike worked only the first battery then the rear wheel stoped turning. The dissapointment was huge. And I read that there are a lot of people around that have the same problem. So I tried to fix it
The problem was a wire that was wound up in the main gear of the rear wheel. This wire cames from the inside of the bike, so I can imagine that a lot of people will have this problem.
So how to fix it?
It is quite simple to remove the wire parts from the gear. But it is not so simple to open the bike. There are 4 screws but when removing the screws and you try to open the bike it will not open.
The reason is that the gas cap on top of the bike is glued in. So i worked a little bit around of this cap with a stencil scalpel knife. But be careful right under the cap are the wires for the steering wheel. So dont go too deep. Once opened you can easy remove the rear wheel and the gear to find the ugly wire wind up on the main gear. In my bike the wire was directly in the small gear on the main motor. It took a while to remove all parts of this wire.
But once removed the wire the main motor will turn again.
Put all gears in the right places and close the bike.
In my case all things are fine after this repair.
Good luck
Stefan
Dec 25, 2010 | Spinmaster Air Hogs Moto Frenzy R/c Stunt...
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
How to removal the shaft from the rear end to
In order to remove the rear wheel, it is not necessary to remove the drive shaft. The first step is to get your rear wheel off the ground. The easiest way to do this is to put your bike on its center stand. However, not all bikes have center stands. If your bike does not have a center stand, you may want to buy a motorcycle lift (available from Pep-boys, or Harbor Freight). Once the rear wheel is off the ground, you can disconnect the brake linkage, and then remove the rear axle.
At this point there is nothing holding your rear wheel to the bike except for some meshing gears. Now you must lift and maneuver the rear wheel back and forth a little and eventually the final drive will work free. You will be able to slide the wheel toward the right side of the bike and then lower it to the ground.
In theory removing the rear wheel is that simple. In practice, the gears in the final drive can sometimes hold on quite tightly. This is particularly true if the rear wheel has not been removed for a long time or if your final drive is very worn. Usually being patient and persistent will pay off and you will be able to remove the rear wheel.
Sometimes it may prove easier to remove the entire wheel / final drive / drive shaft assembly first, and then separate them. In this case, the order of operations is different. Once you have the rear wheel off the ground, you can disconnect the rear brake linkage just as before. Next you can remove the four bolts that hold the drive shaft housing to the back of your crank case. Finally you can remove the rear axle and slide the wheel backwards the unmesh the drive shaft.
Regardless of which way you remove the rear wheel, it will be easier to put it back together by first attaching the drive shaft and final drive to the crank case, and then reinstall the wheel as described in the first method above.
Good Luck,
-Josh
Mar 27, 2010 | 1985 Yamaha XJ 700 X Maxim
REAR HUB MAKE NOISE OPEND AND TENCHENER IS BLOWN HOW DO I GET A NEW ONE
I had a problem with the rear hub seizing up, clanking and screeching on
my Dynacraft Magna Imposter bicycle from the day I bought it at Target.
I called the company and they sent me a new rear wheel. It arrived by UPS
in 8 days and my bike has been fine ever since.
Great customer service from Dynacraft!
Jan 06, 2010 | Dynacraft Cycling
Aug 02, 2009 | Cycling
Not engaging in any gears
It sounds like you need a new cassette on the rear wheel. Take the rear wheel to a bicycle shop as they will have the tools to remove the old one and install the proper new one.
Aug 01, 2009 | Cycling
Cycling Logo
56 people viewed this question
Top Dynacraft Cycling Experts
Michial Gueffroy
Tony
shaun taylor
Are you a Dynacraft Cycling Expert? Answer questions, earn points and help others
