Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
Have to constantly reconnect mouse to base station
  • 30 Answers
Definitely clean the connection, in both the mouse and the computer. Blow gently in them first, and try it. If you still have problems, I would take a Q-tip and lightly moisten it with rubbing alcohol (because it evaporates very quickly), and run it inside the connections of both! Let dry, and try again. If you still have problems, consider purchasing a new mouse.
Posted on Sep 08, 2009
My wireless mouse and keyboard do not connect to the base station. Only the FLock green light is on. The A 1 green light flickers momentarily when I try to reconnect, but doesn't stay on. This all was...
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | Computers & Internet
E2125 model
You need to reconnect this phone with the "base". If more than one charger came with this set, only one of them is the base. This would be the one connected to the phone line.
Please place it back in the charger that is the base or home unit.
Brian
If you have lost your manual, I will provide an onlink link shortly!
Aug 04, 2008 | GE 27992GE5 Cordless Phone
The mouse
Hello there.
I recommend doing the following:
1) Shut down the computer (you can hold down the power button on the front of the computer base unit or laptop power button for a few seconds instead of using the mouse)
2) Unplug the mouse base station.
3) Plug the mouse base station in again
4) Turn on the computer and let it start up as normal.
5) Watch for any system messages appearing, like found new hardware.
These steps will verify that there is not a problem with the mouse's base station plugged into the computer. Another thing to check is if the mouse requires batteries, this is often overlooked.
If after doing this there is still no pointer registered, i would suggest trying the mouse in another computer, and if possible trying a different mouse on the same computer.
If the mouse works on another computer then it could be a software problem, which we can help you with.
If the mouse doesn't work on another computer, but a different mouse works fine on the same computer, then im afraid your mouse has to be replaced.
Please post back after trying the above steps and let us know. Telling us which mouse you have exactly will futher help.
Hope this helps.
May 09, 2008 | Logitech Cordless Mouse
I changed batteries and forgot how to reconnect. It is plugged in via USB, batteries are birght. I have pressed the connect button on the base. It flashes but the mouse does not work. I have pressed the...
This is from the manual for the Logitech MX700 cordless optical mouse.
1. Press connect button on Base Station.
Its LED blinks green. 2. Press connect
button on mouse bottom. Base Station LED
turns solid green, and then off.
I hope this helps
Mar 07, 2010 | Logitech MX 700 Mouse
Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Aug 05, 2009 | Panasonic KX-TG1033S Cordless Phone
My mouse will suddenly stop moving new battery doesnt help
Is there a resync button on the bottom and on the base station (that is on the end of the usb plug that you plug into your computer)? Press the one on the base station first, then the one on the mouse within a few seconds.
You could also:
Try another set of batteries.
Try another USB port.
Jul 16, 2009 | Logitech Cordless Mouse
Mouse stoped charging lights on charger stay green but mouse light stays red and wont work most of the time i put regular in and it works but wont charge help please
this is a problem with my mx700. you need to constantly clean the two brass coloured connectors at the bottom of the mouse. an eraser works well. even with this you sometimes need to jiggle the mouse a little in the holder to get it to charge. this is not logitech usual standard and very annoying.
hope this helps.
Mar 01, 2008 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Reconnection
Go to the philips site or look at customer care contact information on your base stations box. You can call or e-mail them or just download new drivers from their site... All of these processes are free...
Feb 08, 2008 | Computers & Internet
Mouse not functioning
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Oct 12, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
48 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
