Cannon Canon i960 Refurbished Photo Printer
Problem for Cannon Canon i960 Refurbished Photo Printer ( EXTRA INK...
Print heads go to left grind
By jerryaycock on Sep 08, 2009
printer power cycles and when print heads go to left, loud grinding noise .
No print...
new ink cart.
Solution #1
posted on Sep 08, 2009
Not Rated)
fredy2
Rank: Wiz  Computer Hardware  Expert
Rating: 84%, 362 votes
The carriage sensor (usually a photocell arrangement) that senses the carriage position when at the end probably has dirt or has failed. It usually is a couple of small black fingers that a "vane" on the carriage goes between. If the vane is broken or the sensor broken the carriage will keep trying to move farther as it cues up. Once it has cued up itself, it counts pulses to the drive motor to keep track of where it is.
Was this helpful?
Yes
No
Popular Solutions for Cannon Canon i960 Refurbished
Questions and Unsolved Problems for Cannon Canon i960 Refurbished
Do you recommend Cannon Canon i960 Refurbished Photo Printer ( EXTRA INK BONUS )?
Answer
Answer
The i960 does not print. The orange light flashes intermitent with the green non-flashing ight 7... (More)
Answer
Colors print as yellow or green. Hearts that should be red print as yellow. Magenta shows blank on... (More)
Answer
I have a i960 Cannon Photo Printer.When I try to print with just a black cartridge the printer works... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cannon Canon i960 Refurbished...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
