Question about Dell W5300N Laser Printer
Just performed printer maintenance on dell w5300. Now getting Error 922 Fuser Error message. All connections are secure. Reseated everything and still getting error.
I am getting a 922 service fuser error on my lexmark optra s 1855
922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
"922 SERVICE FUSER ERROR"
920, 921, or 922 Fuser Error:
The printer thinks the fuser unit is not heating up to the correct operating temperature. This can be due to a bad fuser lamp or possibly no power getting to the fuser unit. As a customer, the only other thing you can do is to check the connections on both the fuser unit and where it goes into the printer. Make sure neither connection is damaged. If you are a technician working on the printer, you can check the voltage coming off the system board and Low Voltage Power Supply (LVPS) to make sure power is getting to the fuser unit.
Don
Jun 04, 2009 | Lexmark T520 Laser Printer
Print head problem
Do a reset:
Dell Printer reset
1. With the power on,unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket.
Dell Printers
To run a nozzle clean, perform the following steps:
1. Verify the All-In-One Printer 922 is powered on and connected to a computer.
2. Verify that the paper support (input tray) has clean, plain white paper loaded.
3. Press the Menu button.
4. Press the Down button until Mode: Maintenance appears on the LCD screen.
5. Press the Menu button.
The Dell 922 Maintenance Menu appears on the LCD screen.
6. Press the Down button until Clean Cartridges appears on the LCD screen.
7. Press the Start button.
The AIO 922 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 02, 2009 | Dell 922 All-In-One InkJet Printer
The printer is showing ready maintenance on the screen
The printer keeps track of how many pages you have printer and will notify you when you need to install a maintenance kit and perform a maintenance reset. You can order a kit here and there is a video on how to install and perform the reset.
http://www.fastprinters.com/dell-fusers-maintenance-kits.asp#W5300
Mar 17, 2009 | Dell W5300N Laser Printer
DELL W5300 PRINTER - GETTING THE MAINTENANCE COUNT
It is like your oil light coming on. It means the printer has reached its pages count where they recommend changing the maint kit. (usually new fuser / rollers). If print quality good - let it go - it will work for another 10,000 pages or so. If print quality bad (streaks and rough spots) it needs a new fuser. After replacing the kit you reset the count to zero and it start counting again.
Feb 27, 2009 | Office Equipment & Supplies
How do i get into a dell w5300 to change power supply?
You can remove the side panels and then remove the cover over the power supply. You'll also have to remove the fuser connections.
Jan 07, 2009 | Dell W5300N Laser Printer
Replaced Color Cartridge, now printer will not print in color.
You need to check if the color cartridge that you received is not dried up from the time you received it. You can try and perform a nozzle clean test from the Dell All In One Center (click on Maintenance and you have several tests to fix various issues regarding ink).
If ink was bought from Dell contact them, as they sort out most of the issues.
Mar 16, 2008 | Dell 922 All-In-One InkJet Printer
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
Dell W5300N Laser Printer Logo
412 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
