Question about Dryers
Everything seems to be working fine but there is no heat
  • 864 Answers
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Posted on Sep 08, 2009
The radio and heater have no power. everything else seems fine
could be fuse under dash check all fuses in the fuse block.
Jan 02, 2014 | 1992 Buick LeSabre
Microwave appears as though it is working, however only heating sporadically... sometimes does not heat at all.. others heats well.. seems to be hit and miss. It is only 2 years old and everything else...
Hi. Microwaves are not the kind of thing you want to work on yourself, and one that is malfunctioning can be dangerous to those near by. If the warranty is up your best bet is to recycle it and get a new one.
Sep 09, 2011 | Vacuums
I have a dle2532w and everything seems to be working fine but there is no heat, I have checked my breakers and everything is fine. I took it apart and checked the element and the thermostat and the thermal...
You need to replace the operating thermostat along with the thermal fuse. This thermostat controls temperature in the drum and if it fails, it will just put out heat constantly without regard to temperature. Be sure to check the exhaust vent in the house walls to make sure they're cleaned. Good luck
Jun 20, 2011 | LG DLE2532W Electric Dryer
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
Whirlpool dryer model LER3624jq0 has no heat but spins and works fine besides that..fuses are good, the heat coils are getting electricity but just wont heat up.. seems like everything is workin fine just...
They could get electricity but when the coils are broken into the will not heat. Diaphram is at AppliancePartsPros.com I dont actually know them but I found my parts there.
Oct 10, 2009 | Whirlpool Dryers
Dryer not heating w/o indication
It's very possible that you need a new heating coil. This is an easy do-it-yourself fix if it's an electric dryer. Save all your receipts and purchase the replacement part from a business that will give your a refund (minus a small restocking fee perhaps).
May 14, 2009 | Dryers
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Water heater doesnt heat up
has the unit every been cleand you can check the it in the service door
Dec 01, 2008 | Water Heaters
Dryers Logo
74 people viewed this question
Top Dryers Experts
