Question about Cell Phones
I dropped my Nextel blackberry and the screen froze. I took the battery out to reset it and now there is only a blank white screen all the time
Blackberry screen keeps turning white but is alright when i charge it
It sounds like you're having problems with your processor. I would take it into a repair shop
Nov 24, 2017 | RIM BlackBerry Curve 8520 Smartphone
I locked my phone. Every time I unlock it I would have to put my password in. I put my password in, and it said incorrect. I know it was correct, I don't forget my password. So I kept trying it and trying...
You will need to reset the phone for everything to return to normal. I would advice you perform a double soft reset, though it is a bit tactical. Performinga SOFT reset on the BlackBerry device Performing a soft reset stops allapplications on the BlackBerry device by pressing the ALT+RIGHTSHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between theBlackBerry device and the computer.
Performinga DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stopsall applications on the BlackBerry device and is nearly the equivalent of ahard reset. Timing however is critical. Perform a soft reset by pressing theALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen isno longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You shouldthen see another blank screen followed by an hour glass. HOPE THESE HELPED
Apr 24, 2011 | RIM BlackBerry Storm 9530 Smartphone
Blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Jun 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
Sep 25, 2009 | HTC G1 Smartphone
I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
Aug 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Nextel i576 blank scree, batery fine
how to reset blank screen on nextel i576
Aug 03, 2009 | Nextel i836
JVM ERROR 547, PHONE WONT COME ON AT ALL
FIRST CHECK WITH YOUR PHONE PROVIDER to see if you must use a special version of software ! If not proceed >>
BEFORE ANYTHING !!!! use the desktop software to backup your data on the BB (if you can) and save the file to the desktop. next go to https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4you need to download (use pull down menu)blackberry desktop software 4.6 and the Blackberry device software for your model phone. install the desktop software first then the device software.. this can take maybe an hour (not including the download time)
Jan 13, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl 8100c Screen blank out
i want to change the network code of blackberry peral 8100
how i can unloack the phone
IMEI = 355767018968151
Dec 22, 2008 | RIM BlackBerry Pearl 8100
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
