Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Water leaking out of breather
When flushing, water leaks out of breather cap on saniflow, sometimes only teaspoon ful sometimes half a mug full. saniflow plus has been fitted aprox 8 months. have checked inside no foreign bodies.
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Posted on Nov 08, 2009
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
How do I clean each of the water dispenser on model 3010 hamilton beach
You can use white vinigar or baking soda. I use baking soda because vinigar will dry out the seals over time. If you use baking soda, mix a teaspoon full in a small amount of water to break it up, fill the unit half full of water, add the mix, fill the unit with water and run the unit as normal. If you use vinigar, add one teaspoon to a full load of water and run the unit as normal. When the cycle is finished, fill the unit with plain water and run again to flush.
Hope this helps.
Oct 22, 2014 | Coffee Makers & Espresso Machines
Saniflow runs, but not straight after flushing
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Jan 30, 2013 | Saniflo Home
Model MDB5601AWW leaking around the side plastic box on left wall inlet that has water hose. What needs done?
-Here sample solution.
-The plastic box or cap you're talking about is the " Breather Cap"
-Check the drain tube from the breather cap to the sink. It must be clean and no block.
-Make sure the breather cap stays in up right. (Straight Up)
-Check the breather cap's Cap . Any big chuck of food waste stuck inside or not. If so the clean it.
-Check the whole breather cap. Any crack...? If so the replace new one.
Good luck ,enjoy and wash every day
Mai
Oct 25, 2017 | Maytag MDB5601AWW Energy Star Built-in...
Oil cap and dipstick covered in creamy sludge, is this breather prob as not losing any water
Yes, it could be that a plugged up Positive Crankcase Ventilation (PCV) valve or engine crankcase breather (with filter) is the cause allowing moisture to condense in the crankcase. However, if the valve and breather are okay, a cylinder compression test should be done to verify that the cylinder head gasket is not leaking. Regardless, the engine oil should be drained and the engine flushed with clean oil and an appropriate crankcase flush additive. Entrained water in the oil (the creamy sludge) will damage engine bearings quickly.
Mar 05, 2011 | Volkswagen Golf Cars & Trucks
Bad smell fro macerator when toilet flushed after being left overnight
Typically on macerating or grinder pumps there is a small 1/2" breather hole on top of the lid, about the size of a dime or nickel. That breather hole must be kept plugged or seal cap. If left open, odor will escape through there. Make sure the pump is vented using an 1 1/2" vent pipe which must be vented to the open air so air can flow in and out of the vent pipe at all times. Also you might want to check for loose connection or waste water leaking from the pump, toilet or any of the connections.
May 21, 2010 | Saniflo & Saniplus& Macerator Pump
Jiffy lupe said i need engine flush for my 2002 Jeep Liberty
No, this is not normal. if you have coolant or water leaking into the engine piston chambers, you will need a head gasket not an engine flush. if you open the oil cap to add oil to the engine and you see a lot of gunk under the cap, then its time for that flush. I would be concern about the more serious issue and that is that there is coolant or water leaking into the combustion chambers. this is a sign of a bad head gasket.
please rate and god bless..
Mar 26, 2009 | 2002 Jeep Liberty
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
767 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
