I have a pixma mp210 and it's showing me an E and an E BACKWARDS also on computer asks me to press the start button I do that and nothing happens
How do I scan docs to my PC with using Canon MP210 Pixma? Upon scanning, I am asked to chose a program, but how do I know which one. If I click on PDF, nothing happens. What do I do next? Nothing...
Open Solution menu from your desktop and choose Scanning Photos. Now put you photo on scanner board and press preview from your solution menu. After preview completing press scan... thanks
Aug 27, 2011 | Canon PIXMA MP210 InkJet Printer
My printer does not feed the paper and shows error 13. It's a canon mp210
E 1, 3 is an Ink level cannot be detected error.
You can bypass this error to continue printing
by pressing STOP/RESET button for at least 5 seconds.
Jan 25, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My canon mp210 printer doesn't print. It shows error 2, 7 and the computer shows message "printer absorber is full"
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
  5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 05, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
The waste ink absorber is full
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 30, 2010 | Canon PIXMA® MP210 Printer
Nothing comes out my printer even when i have paper inside. i press print and nothing happes
Go to Start, control panel, and then printers. Then double click on it and delete all the documents in there and then hit the X button. right click on the printer and hit delete. then unplug the printer usb from the back of the computer and plug into a different usb port
Dec 23, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
What is error code 2 on a canon MP210?
This steps may solve your problem.
1.Load paper correctly then press black or color button (MP210)
2. Press on/off switch to reset the multifunction device
3. Remove Packing Material MP210
4. Reset ink cartridge MP210
5. The MP210 may require repair
If your printer is new , make sure the packing material inside the printer has been removed. You should have a quick setup page and/or users manual that will show you how to remove any packing material that is inside the printer.
If this is an older printer that has worked in the past, start with step
1, 2 and 4. If this does not work contact the Canon customer s
Dec 13, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
PIXMA MP210 scanner wont work. when i press scan it says SELECT PRGRAM TO SCAN TO, no matter how many "softwares" ive download from the canon website and others NOTHING WORKS
Hi
follow this steps
1.unplug your printerfrom your pc
2.uninstall canon driver from your pc
3.run setup (without connecting printer to pc)
4.connect your printer only when setup ask you to
pls vote us to keep us alive
Nov 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I have refilled my color ink. After it prints 20 pages it lights up the "color ink" button meaning it's out of ink and starts printing poorly. I tried refilling twice with new ink - same thing happened.
Try this, it will reset your counter.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset
Sep 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Reseting mp210
i've refilled mp210 both cartridges.do you know how to reset the printer?cause it's show error 6,please help
Mar 30, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
18 people viewed this question
jasbo
jasbo
