Question about Craftsman Air Tools & Compressors
Have a Craftsman Professional 150 PSI 25 Gal 1.8 HP compressor. When this compressor starts to run it seems to run very hard and only runs for a few seconds and then the motor trips off. When I retry to start it again it runs a few seconds longer and after 3 or 4 tries it continues to run. Can you help.
  • 5,603 Answers
Sounds like one of the following three possibilities:
Too small of service to the unit... You need 20 amp and #12 wiring.
Too long extension cord with too much voltage drop.
The "unloader" is defective. This is a little valve that MAY be a part of the pressure switch that bleeds cylinder head pressure at shutdown to make starting easier. At shutdown you can usually hear it "exhale".
Posted on Sep 09, 2009
Testimonial: "Thanks Gives me good ideas to try."
  • 3 Answers
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
Posted on Feb 17, 2013
I recently purchased a 20 gal/1.5 HP, model 921.166420. The reset button on the side of the motor, (thermal overload Protector?) cuts out repeatedly. The few times where the motor did run and the pr
Could be weak thermal cutout or actual problem with unit. Thermal cut out easy to check with amp meter. Connect meter as required to monitor draw as unit fills and make sure that it stays at or below usage stated. If amp draw stays below stated usage and thermal cuts out, replace the part. If amp draw goes over amount stated turn off compressor and listen for air leaks (usually check valve will leak back pressure to pump causing extra load on motor).
Nov 29, 2011 | Craftsman 150 PSI Air Compressor
Will not get above 25 psi and will contune to run
you may have a seal in the head that is blown out or a diaphragm problems start by taking the head off and inspecting their
Feb 20, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
I have a 25 gal. craftsman oilless air compressor. Runs for about 1/2 a minute & than kicks the breaker out.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
Jan 16, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 6 gal, 150 psi craftsman compressor. There is a leak under the plastic housing. How do I seperate the tank from the compressor?
This product manual will show the exploded view on how it comes apart/goes together:
http://c.shld.net/assets/own/00915216e.pdf
Jan 06, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Mar 07, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor won't build psi above 30,is this typical of the regulator or pump? the compressor is a 3 gal craftman about 1 yr old.
sounds like the regulator is faulty, normal running air should reach 110 psi, this will allow you to run tools...
Jan 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 30 Gal. 150 PSI Not building air over 45lbs
The compressor valve may have a faulty gasket or seal, and maybe leaking air internally. Or the compressor might be going downhill. You can try to replace the valve seal and see if that makes a difference, otherwise you need to replace the compressor.
Aug 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
My craftsman air compressor model 919 16737 1.1 hp 17 gal 150 psi won't build up any air pressure. It runs but sounds a little odd.
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Aug 24, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
360 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
