Dometic 57915.531 Air Conditioner
Problem for Dometic 57915.531 Air Conditioner
57915-341G9 AC. unit is tripping the 20amp breaker
By dianne_corte on Sep 08, 2009
57915-341G9 AC. unit is tripping the 20amp breaker intermittenly. while unit is running it is pulling between 13 and 17 amps on high cool. then the compressor will drop out pulling 2.5 amps then it will spike up to 39 amps until the breaker pops. reset it and it will work fine sometimes and then start again.
Solution #1
posted on Sep 09, 2009
Somewhat Helpful)
scarfoot203
Rank: Wiz
Rating: 84%, 28 votes
Sounds like the compresser is bad,I have seen a freon overcharge also do this-but it is rare.
Was this helpful?
Yes
No
Popular Solutions for Dometic 57915.531 Air
Questions and Unsolved Problems for Dometic 57915.531 Air
Do you recommend Dometic 57915.531 Air Conditioner?
Answer
Answer
I'm in Tokyo and my apartment has National CS-401A2-W airconditioner, the problem is how do I turn... (More)
Answer
My Gold Star Dehumidifier is making a rattle noise and the fan is not working
Answer
I've got a tatung tv model v27dmbx-u02 that will not power up. I've replace the power supply cord... (More)
Answer
Is there any cheap and easy way to replace and install the heater core,can you suggest anything?
Answer
My Ecoquest Fresh Air Needs a new RCI Cell. What does this do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic 57915.531 Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
